Yep. The board crashed (due to a failed RAID controller) and Christian's had to rebuild his database. At first I thought I got kicked out for saying something wrong considering I only just registered the day before! After reading the sticky about the outage, I figured I had to re-register and we're back to normal now, more or less.
rianto has it. and yes they are NOT cheap. not to mention theres still a lot of custom electronics to maintain teh extra options.
Given the composite video input that one can tap into with the V35's, for those who are only concerned with the GPS, I'm thinking one could use the Garmin GVN53 interface as a cheaper alternative. Of course, that would only be an ideal solution for those who don't care much for the stereo and translations. A bit hard for me to tell without a V36 (which won't be until March/April for me) but that's my guess for now. What's your take on this?
up to you. the video in on a 35 has limitations. picture looks a LOT better with RGB applied to it.
I use the GVN53 when I do the 35s. though I use a slightly different version.
if you buy a CKV36 then the full swap is the BEST way to tackle it.
if you read the description they are only installing TV tuner to allow viewing of UK TV Channels. Nothing in the navigation or menus are converted/translated.
its exactly the same to what Chris has been doing, adding an Australian compatible TV tuner.
I think he's still pretty busy... he just finished mine today... I got reverse camera now, although it doesn't tell me 100% whether I'm gonna hit something or not but at least it's helpful to see what's behind me with 150 degree wide angle view....
hm, chris the way you mounted the camera so low, it's very strategic when reversing against a bunch of chics in mini skirts... LOL
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
