  • Replies 153
Wow I can't believe your putting NOS in. I doubt it will make 200kw...well not at the wheels anyway.
The bad thing about some NOS systems is they're not progressive and come on too strongly, 75hp sounds alright.
If you insist on staying N/A and not going FI, bang for your buck - cams and power fc ... it would make the engine much more elastic in the rev range, might lose a bit of bottom end depending on what cams you going.
Little concerned about the placment of the NOS jet Cara, being in only one side of the two intakes you may not get an even distribution to all cylinders. As a general rule of thumb they should always be at least 6 to 8 inches before the throttle body for an even distribution to all cylinders.
I was at High tech dyno today fiddling with the fueling on the dyno as my tune was alittle too rich, just on idle chatter about various cars with one of the tuners, your atmo Nitrous+PFC subject came up and coincidentally I see the topic here today.
Very interesting to say the least, good luck with everything :)
true but go race a turbod car. :)
See how it goes.
why? i don't like the smug tone of your post.
race your car against an F430, see how it goes.
this is the naturally aspirated section and more specifically cara's thread about her nitrous progress... please keep it on topic.
You got the wrong tone.
I'm pretty sure i read clearly that this is the NA section also, what this thread is on.
I'd be more than happy to go up against a F430. Wouldn't you want to try?
Have i said something off topic? I was just saying to take it against a turbod car and see how the nos goes.
I wasn't saying, that this idea was stupid and that putting it up against a turbo it still would have no chance.
Geez.
if that's the case then i take back my comment and offer my apologies.
very often we get people in here who preach 'turbo'. reading your post in different light, i agree - that would be a test to try out. however where do you draw the line in terms of comparison? same power output or same amout of money spent?
with what you said, going head to head with a mild GTSt/GTT would be evenly matched - driver pending.
CARA!
YOU SAID YOU WONT BE STINGY ON THE PICS!
:nyaanyaa:
Hows she go?
agree with john. i think 3 & 4 would get a larger amount of nitrous than the others.
direct port injection :w00t:
I dont think so.. The pistons cause vacume and hence suction at different times.. the valves will be open to allow the piston to create suction and taking in the bulk of the NOS. Because not all 6 cyl's are creating suction at the same time ther isnt much "comptetiton" from others. Residue may be left near cylinders 3 and 4. But they wont be getting significantly more NOS than the others..
Not sure if this makes sence.. cos I have a feeling it dosnt..
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
