Good day fellas,
I just went down to Calder last nite and ran a personal best of 13.06 @ 108mph in my rb20det R32 Gtst...
Car was running 18psi and was making around 210rwkw...was on hankook rs2 street rubber and was in full street trim...didn't even pull out the spare tyre...
I'm so agonisingly close to a 12 on street rubber and trim but getting that extra 0.06 seconds will probably be too much for my poor little engine...we'll see though...it might just eat away at me too much and i might give it another go after summer if she's still alive and kicking then...
Cheers...
Edited by limpus
https://www.sau.com.au/forums/topic/195900-ran-a-130-on-my-rb20det-r32/
Thats the problem...damn calder print outs yesterday didn't show 60ft times...i was aiming to monitor those times...
In terms of mods...its got all the usual bolt on support mods like exhaust, fmic, remap, injectors and runs a hks2535...made 217rwkw at 19psi in winter at dr drift's dyno...still have some restrictions in the system which i might aim to sort out over the coming months...
Edited by limpus
2535 isnt gonna make mountains more than that.
Maybe another 20rwkw or so.
I was running 109mph/12.9 with a car a bit over 1400kg and 210rwkw myself with a 2.160ft
Just need some more traction and you should be able to pull that down to a 12.8/12.7
Practice makes perfect, and you have a nice set-up there, love the 2530/2535 for the RB20. Great turbo :)
Spewing...
I have some nice 'street tyres' here you could have borrowed... 235 semi comps :)
Lolz Sam...then they wouldn't be street tyres would they...
By the way sam...the car is still hitting a flat spot on hard shifts...can we try to sort that out sometime?
if those are the 'street' tyres i'm thinking of then i can vouch that they've spent their whole life on the street :)
i get the same thing with the flat spots - need to add fuel to those points on the map. Yours is a remap yeah?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
