Well fellas,
as the topic suggests... I've driven a few of my mates's R32's and have recent been driven around in a mate's R34 and for some reason - even though my mods and his mods are very similiar, e.g. BOV, FMIC, Blitz/Apexi Pod - how come only the R33's have the nice and aggresive suction and flutter sound as opposed to the R32 and R34 where close to no sound comes from the Pod?
I don't understand, the engine set up e.g. is pretty much identical?
Cheers,
SM. :whistling:
dude my 32 has more induction sound then i can poke a stick at. its almost annoying. even light throttle so its only boosting like 1psi will have a slight sucking sound more then able to be heard in the cabin. nothing out the ordinary either, normal pod/cooler/exhaust mods.
maybe your mates 32's and 34's are non turbo. :)
seriously though... dont know where you would get that . All have the fulli sick suction sound if there turbos and got a open exposed pod. Some pods will be louder than others but still...
my mates 32 has similar mods as my 33 and his is louder.. go figure
at the end of the day, who cares.
Edited by jake33
That's strange... the R32 I drive had a pod, front mount, BOV etc... so does my car... my mates R34 has similiar mods... but for some reason, mine sound much more aggressive.... I don't know why...
the suction sound can be affected by the filter itself, some are louder than others.
the suction sound can also be affected to what boost level your running, more boost, more suction, more noise.
The "flutter" sound is compressor surge, and that is affected by the setting of the bov. If the bovs spring is set hard, then its not going to release the intake charge as much as a soft set spring, therefore you will have more "flutter" going back through the turbo and out the pod.
Even though you and you mates may have simular mods, ie pod, bov, fmic, the brands themselves and they way the are setup can affect the noise
Edited by R34GTFOUR
I have loud as shit induction noise while I'm still at 10mmHg!
You don't even wanna hear it when it comes on boost! It sounds like a pure animal if you're driving alone beside it.
Mind you, 3" stainless pipe from motor to filter helps with this... Then I must also have a "noisy" pod...
yeah metal intake piping makes a huge difference to intake sounds. The stock rubber intake absorbs quite abit of the induction sound, put a nice alloy or stainless pipe in place of it and you'll notice a nice jump in db's haha
Your has fully sick rebuilt engine from japan.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
