Its been a few months since I have sold my GTR. Its been quite depressing to tell you the truth. Three months without any adrenalin rush has driven me crazy.
So I've booked in a Skydiving session on Saturday.
Not sure what to expect, I am confident as usual :nyaanyaa:
Anyone else done it before, any tips at all?
I'm going to look into getting a certification (obviously a few more sessions to follow) and then be able to jump alone.
It's the tandem jump by the way, 10,000 feet off Bell's beach.
For all you guys who love posting pics - make sure its not of a person who's parachute failed !!
https://www.sau.com.au/forums/topic/196487-skydiving/
My tip is to hold on tight and don't forget to enjoy the ride. You never know when it's your last :rofl:
Just kidding. When I did it, it was heaps of fun! Just enjoy the experience and try to not to get caught up in all the extra stuff they try to sell you. The DVD at the end is pretty good but that's bout it.
https://www.sau.com.au/forums/topic/196487-skydiving/#findComment-3516455
Ash: I'm full of confidence mate, I don't see myself hesitating to jump at all. In fact to prove all my family and friends wrong it will be on taped on DVD. Lets hope I prove them wrong :rofl:
Leewah: I'm hoping it will be full of fun. They did say it will be around 40seconds of free fall and around 6-7 mins of parachuting.
https://www.sau.com.au/forums/topic/196487-skydiving/#findComment-3516466
Do the Accelerated freefall course, 2 day course then you get to jump by yourself (ie no tandem) I didn't want no big fat hairy guy strapped to my ass.... ;)
Did that a few years ago, pretty good... doesn't feel like your falling, just feels like you stick your head out of a car window at 200k/h :)
https://www.sau.com.au/forums/topic/196487-skydiving/#findComment-3516799
You think they'll even let you go up in the plane Hus!!!!
Hehehe - JK - you are braver than me.
Sif jumping out of planes is 'fun'.
Hahaha - Can't believe it took that long for someone to make that comment, I was expecting it on the first post :)
Lets hope it's all nice and smooth ;)
https://www.sau.com.au/forums/topic/196487-skydiving/#findComment-3516889
My tip is to hold on tight and don't forget to enjoy the ride. You never know when it's your last :)
Hold on to what? Ya bum?? lol
It's awsome man, everyone should do it at least once.....
and you don't even have to jump, the person your attached to does and you just get pushed.
You'll definately get that rush your craving,,and then some!!! ;):)
https://www.sau.com.au/forums/topic/196487-skydiving/#findComment-3516970
enjoy it because it will be over quickly...
..potentially very quickly
You'll be back. You miss our weather too much, and all you have to drink up there is xxxx.
My girlfriend has a skydiving voucher she got for her birthday, i would love to do it over the x-mas break this year.
https://www.sau.com.au/forums/topic/196487-skydiving/#findComment-3518468
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
