Righteo
I am awaiting an R34 GTT Apexi Power FC unit with hand controller and Boost controller
For a Series 1 automatic Stagea what is needed to get it going.
1st. get an Automtaic shift kit valve body actuator modification done. firm up the shifts. far far quicker than the sloppy stnd shifts. get it ready for the PFC auto shifts.
2nd. install R34 GTT PFC unit and wire up.
3rd. split TPS wire (pin #23) into 2 with one from the ECU to the rear Attessa ecu to give it a tps signal. confirm?
4th-A. either use 510k ohm resistor from Throttle motor sensor signal (pin #51) on ecu to ground
or
4th-B. use 10.3 Volt diode between ignition and pin 51, and a 400 ohm resistor between earth and pin 51
what am I missing?
https://www.sau.com.au/forums/topic/196648-s1-auto-awd-with-power-fc/
i'll be interested in the outcome there tangles , hope it goes good, (giving up your safc/sitc combo), for the extra outlay i hope the benifits are worth it, for you and all of us.
regards leigh.
Sorry no sale of the piggybacks as of yet.
I was going to do the $1300 drdrift ecu remap and run the piggybacks still with it all for finetuning, but I found the PowerFC kit for just over a grand.
thought Id try it first, hold my piggy's and see how it performs for 6months (car + auto).
plenty of auto R33 skylines run with the power fc successfully, I know a number in SA with varying degrees of mods (from 200rwkw to 330rwkw)
just got to get the awd + engine + ecu + auto working smoothly, and then see how it goes.
if I keep the setup, if it feels good, then I expect a rebuild of the box in ~3yrs time, to last another 7+yrs
............. nothing different to replacing gearboxes and clutchs and pressure plates and all that manual jazz.
I wouldnt do this with the auto with out the quick shifting auto shit kit. Ign retard at gear changes wont be a huge factor over the long term, I hope, as Mike from MV Autos knows his skyline autos and this is the best shift kit going around. When the box goes I'll take it to him for a kevlar band rebuild jobbie, in liue of 3months of morgage payments ;)
and if it all isnt good at some stage, can still do the remap to the stnd ecu, and Power FC's will still be in hot demand for a rarish R34 GTT item
anyway, what am I missing
what wires need to be spliced and rewired - pics?
any pics of the attessa ecu wire ?
I'll get a tuning house to wire and install but I need to be prearmed with info but I dont understand this "use 10.3 Volt diode between ignition and pin 51"... what ignition - wire at ecu or wire at key insert, ??
bump
http://www.skylinesaustralia.com/forums/Se...32#entry3531132
eccs pinout for Stagea, costs $5 US to download but $10 US to join site. worth it IMO. copyright tho for private use only.
From a quick look at it, the Attessa shouldnt be affected, but I'll test this for sure.
Will wire up with Andys diagram (cheers - "use 10.3 Volt diode between ignition and pin 51, and a 400 ohm resistor between earth and pin 51")
then setup a basic map, then putter down to a garage and get on a hoist and test to see all 4 wheels spinning ;)
then disconnect until tune time
oh, received the R34 GTT Power FC today, with boost control kit
me happy
you have a series 1 stagea, which has a series 2 R33 motor, correct?
if so, the R34 PFC wont work, as its for the NEO engine, which has a few electronic differences, unles you are going to re-wire it.. (for the the CAS wires are completely opposite)
It will work
rewiring will need to be done, not much tho
the Stagea ecu uses a R34 ecu plug
as simple as that
Very much looking forward to seeing the results of this!!
So will this mean you need to change gears using the shifter or will the auto work as per normal?
Going from the discussion a while back about whether the auto will be fully supported or not, SK mentioned it probably wont be as smooth in all situations or as nice on the gearbox as with the stock ecu...
I guess with the shift kit its not as silky smooth as stock anyway (though not rough either) and the gearboxes are strong enough to handle it - as evidenced by the auto skylines running aftermarket ecu's.
Will be interesting to see what gains (right across the power graph) you see by just changing the ecu. Another 20awkw perhaps? You might be at the magic 200awkw fairly soon...
Yeah Id hope for sure for a 200awkw tune
It may be that I have to have a mechanical shifter installed by MVs but there are plenty of auto r33's out there that dont use this, but use power rfc's, so it should be ok.
The only issue I see is cutting and rewiring a couple of wires.
With the correct pinouts (I have R34 skyline and Stagea pinouts, there are difference) Im sure a qualified auto electrician (with full INSURANCE in case the Pfc blows, lol) will be able to do the job for next to nix.
idea - are all R34 PFC's the same? would it help if someone else who's fitted one in a R33 posted pics? or do you have this info already?
that would be nice :ermm:
r34 powerfc's are for GTT's yes, thats all there is for the RB25's
  • 1 year later...
Pretty sure it can't be done. Stagea S1 ecu is unique - plug and pinouts like R34 but different inside. I think Tangles is still using a chipped daughterboard in the stock ecu supplied by Toshi.
I plugged it up and it idled fine
didnt want to trash my auto gearbox with the lack of ignition retard on gear changes, so didnt go ahead and did the remap instead
240rwkw from the remap + GT3076
better driveability with the auto than power-fc.
difference is I cant drop in injectors without doing a complete fresh remap
Brendan you say the PFC idled fine but did you actually drive it? I have doubts that on an S1 it would even change gear let alone pull timing on changes.
I hadnt done the "secret squirrel" trick - had the bits right there, but wasnt game to DIY
was awaiting to get the setup to the tuners, then at last minute convinced myself that while a) it was going to work after some wiring tricks, b) it wasnt worth it due to undoubtedly the auto seeing early death.
had an offer to sell the P-fc, and before I knew it had the Toshi remap setup instead
:) 1
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
