trying to gather some info on street response turbos for the r34 gtt.
theres alot of speculation but it seems like the gt35r is the way to go.
any suggestions and help would be great.
im after the most usable street response possible.
thanks in advance
Edited by R34NRG
https://www.sau.com.au/forums/topic/196816-ideal-turbo-for-street-use/
Do a search for SydneyKid's specs on his R34 GTT using a GCG Hiflow turbo setup making about 270rwkw with stock turbo-like response.
i dont believe any highflow will outbeat a larger size turbo like the gt35 but ill have a look thanks
Edited by R34NRG
I honestly think there are too many people making mongrel-spec highflows with unknown performance. Exhaust housings are limiting in some and not others, a properly designed HKS, Apexi or similar is the way to go.
^^ exactly what i was thinking.
Silly question this really
You cant have both.
A GT35 (as spoken about here dozens of times), is a 300rwkw+ turbo. Its not going to have close to the stock response.
GCG Hi-flow (again, well covered), is a ~260rwkw with almost stock like response.
What do you want, power or response?
like i said above i want response, most street ability possible.
You cant have both.
so ur saying the hi flow will out perform a gt35? we all know of turbos that only hit boost at like 7000rpm which is useless and not wat im looking for. but comparing a highflow with a gt35, the highflow may have the advantage hitting boost slightly quicker but i doubt it will make any difference wen the gt35 hits boost.
correct me if im wrong but the gt35 will composate for that second it does lag with the extra amount of power.
again like i said im lookon for response and feedback of course, if ppl have experience where a highflow has outperformed the gt35 let me know.
GT35.....LOL
Ill see you at 5,000RPM shall I......you call that streetable???
5000rpm?!??!? shit maybe im confusing myself with another turbo but i thought id see full boost at like 3800rpm
someone should clear this uip for me lol.
does anyone know how identical the highflows are to makn full boost compared to factory.
Edited by R34NRG
I think what they are saying is for street use, hitting boost at 5k rpm is pointless. Also said above, you cant have both...
i think thers a miscommunication here. i know i cant have response and power. im fine with a little lag, as long as when it does make power it componsates for the lag. im not talking about 5000rpm and starting to make boost.
okai how bout we look at it like this.
"theoretically", over lets say 150-200m a highflow or a gt35. which would finish 1st
call me lame call me a hoon wat ever, i rkn this is the best way to explain to get results lol
300kw+ at the rear wheels is pointless if
- you cant drive
- you have stock suspension
- you cant afford insurance
- you want to keep your licence etc etc
what sort of cars have you driven?
honestly a 200rwkw gtst on the street is fine
you can take down most cars and take anything off the line if you can drive and be responsible
a GT35r on the street is gonna net you seeing 100km++ before it even winds up and goes hard
so youll just amplify any fines, accidents etc you have
a stocker v8 will take you off the line no worries with all the lag you have
then when it comes on boost - youll have wheelspin city
guess it depends - but do what you like dude, no matter what anyone tells you, you will buy what you want
In all honesty, use the search function and read some more information.
There is plenty of info, and it doesnt seem that you have grasped things at all.
A GT35 is a 700hp turbo, where a hi-flow is around 450-500. How can you possibly compare apples and oranges?
Please read the sticky thread (dyno results), and then search on the Turbo frame numbers (GT35, GT30, GCG) etc.
thanks
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
