Maybe my quality of chix is higher than yours .. I duno ..
Id much prefer the women in ur avatar tho.. sure dont see many of those leaning against my ride..could be her buldging boobs swaying my idea... maybe I should buy a ferrari.. although mine is faster :D
yeah love boobs :sorcerer: :P
ps spend much to get your 34 do go from 0 to 100 in less than 4.5? :) :)
Id much prefer the women in ur avatar tho.. sure dont see many of those leaning against my ride..could be her bulging boobs swaying my idea... maybe I should buy a ferrari.. although mine is faster :P
this one might be better for you then: http://www.ifilm.com/video/2860133
Actually I didnt spend much .. We dont understand why the car is so fast.. but fried a testarossa and 455 the other day.. I dont know if it would take that but just assuming lol.
Must be a generalisation that Ive betten a ferrari so I can take anything lol which we know is not true.. when i get it retuned ill run it 1/4 mile and let you guys know haha
And that one you posted.. shes ugly like dog shit but tits on a platter.. gr8 ... n she launches it .. but backs off around the corners :thumbsup:
Edited by DECIM8
you guys are tough. she may not be able to shift like many of us but i was kinda impressed with the way she handled a notoriously difficult ferrari gate.
You have to be precise with them. I know because i worked on ferraris in the past and i missed gears often!
holy cow...did God actually create women with bodies that looked like that???? AND she knew how to drive!
sensational.
Edited by m3gtr
And that one you posted.. shes ugly like dog shit but tits on a platter.. gr8 ... n she launches it .. but backs off around the corners :banana:
lol, id like to see a picture of your girlfriend.
def is better
same one of the first chic but just reving the 360: http://www.youtube.com/watch?v=
and lol!!!-> http://www.youtube.com/watch?v=k7uaOlyiuCQ
the music is soooo stupid - chics are hawt though
Also could you pls share with us your secret of building a ferrari beater with a stock turbo and ecu... Unless... you have stripped the car to the weight of a bike somehow....... :thumbsup:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
