Nurburgring Nordschleife Falls To The Mighty 911 Gt2 In 7:32
From StreetFire.net
"o Nissan got to enjoy a brief stint in the sun ahead of the 911 Turbo, only to have their 7:38 time in the new GT-R cast aside by the all new Porsche 911 GT2. It's only a matter of time before Nissan debuts their V-Spec, but for now the GT2 has the bragging rights."
Hopefully The V.Spec can Pull something out of the Bag.
  • Replies 48
When your driving around a track that is over 20 km around, goes up and down lots of hills and all over the place there are bound to be some damp spots.
ZOMFGBBQ teh new GTR suxxors rofl
From StreetFire.net
and around and around and around we go
Nissan will probably focus on the V spec now and slash another 6 seconds off the clock.......then Porsche will go and bring out a special stripped out version of GT2 and shave another few seconds off that.....and then V spec 2 will beat the uber GT2 and the fight goes on.
I hope so , that sounds sweet
A stripped out GT2??? have you seen a GT2? there's hardly anything in there to begin with
I was under the impression GT2 still had some stuff left in there
I only remember the GT3 being so bare that it would make a stripper blush.
I'm don't know porsches that well so I could be completely off the mark here
gotta compare apples with apples. It's GTR vs 911 Turbo (or even a base 911 really) and GTR V-Spec vs GT2/3, etc...
the GT2 had already recorded a quicker time around the Ring a while ago, they've just gone around again for shits and giggles. Porsche had already posted a GT2 time before the GTR went around.
Who cares really, the luxo GTR is a few seconds off in full trim on a damp track, with a $220-$250k V-Spec version to come which will smack the worried grin off Porsche's faces again
and Porsche would not give a shit about not selling their GT2's as quick as Nissan's GTR... Porsche aren't trying to knock off Toyota in sales volume stakes
well said :thumbsup:
You are thinking about the GT3 RS, which comes with a rollcage as an option.
Damn, was it Walter Rorhl that did that 7.32 in the GT2?
Nissan still has the advantage, I'm sure the "average" driver would be faster in a GTR (V-spec or not) than the GT2 - plus its much cheaper. By a lot.
Nissan never went out to bench mark the R35 GTR against the GT2. It was always a comparison between the 911 turbo and the GTR.
Having said that, I wonder how the R35 GTR in GT2 spec (RWD, less luxuries, less weight etc) would fare. Not that Nissan will ever do this as their AWD is a massive advantage.
RWD in stripped out spec....I like that.
ive always said, i wanted the V-spec to be a RWD version with both manual and twin clutch auto options, with the RWD will change the weight distribution, meaning gear box mounted back so far isnt needed, hence it can run up to the engine, hence the possibility of a manual option :)
It will never happen as AWD makes the GTR faster around corners and off the line. I don't know how the GT2/3 manages to achieve such good cornering ability and yet be quicker.
What's the weight difference between the GT2 and 911 turbo? (can't be bothered looking it up :) )
The fact that the gearbox is mounted in the rear has nothing to do with the lack of a manual option.
As mentioned a lot of times in other threads, other cars have rear mounted manual transaxles such as the Corvette's from the C4 on.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
