Nurburgring Nordschleife Falls To The Mighty 911 Gt2 In 7:32
From StreetFire.net
"o Nissan got to enjoy a brief stint in the sun ahead of the 911 Turbo, only to have their 7:38 time in the new GT-R cast aside by the all new Porsche 911 GT2. It's only a matter of time before Nissan debuts their V-Spec, but for now the GT2 has the bragging rights."
Hopefully The V.Spec can Pull something out of the Bag.
  • Replies 48
When your driving around a track that is over 20 km around, goes up and down lots of hills and all over the place there are bound to be some damp spots.
ZOMFGBBQ teh new GTR suxxors rofl
From StreetFire.net
and around and around and around we go
Nissan will probably focus on the V spec now and slash another 6 seconds off the clock.......then Porsche will go and bring out a special stripped out version of GT2 and shave another few seconds off that.....and then V spec 2 will beat the uber GT2 and the fight goes on.
I hope so , that sounds sweet
A stripped out GT2??? have you seen a GT2? there's hardly anything in there to begin with
I was under the impression GT2 still had some stuff left in there
I only remember the GT3 being so bare that it would make a stripper blush.
I'm don't know porsches that well so I could be completely off the mark here
gotta compare apples with apples. It's GTR vs 911 Turbo (or even a base 911 really) and GTR V-Spec vs GT2/3, etc...
the GT2 had already recorded a quicker time around the Ring a while ago, they've just gone around again for shits and giggles. Porsche had already posted a GT2 time before the GTR went around.
Who cares really, the luxo GTR is a few seconds off in full trim on a damp track, with a $220-$250k V-Spec version to come which will smack the worried grin off Porsche's faces again
and Porsche would not give a shit about not selling their GT2's as quick as Nissan's GTR... Porsche aren't trying to knock off Toyota in sales volume stakes
well said :thumbsup:
You are thinking about the GT3 RS, which comes with a rollcage as an option.
Damn, was it Walter Rorhl that did that 7.32 in the GT2?
Nissan still has the advantage, I'm sure the "average" driver would be faster in a GTR (V-spec or not) than the GT2 - plus its much cheaper. By a lot.
Nissan never went out to bench mark the R35 GTR against the GT2. It was always a comparison between the 911 turbo and the GTR.
Having said that, I wonder how the R35 GTR in GT2 spec (RWD, less luxuries, less weight etc) would fare. Not that Nissan will ever do this as their AWD is a massive advantage.
RWD in stripped out spec....I like that.
ive always said, i wanted the V-spec to be a RWD version with both manual and twin clutch auto options, with the RWD will change the weight distribution, meaning gear box mounted back so far isnt needed, hence it can run up to the engine, hence the possibility of a manual option :)
It will never happen as AWD makes the GTR faster around corners and off the line. I don't know how the GT2/3 manages to achieve such good cornering ability and yet be quicker.
What's the weight difference between the GT2 and 911 turbo? (can't be bothered looking it up :) )
The fact that the gearbox is mounted in the rear has nothing to do with the lack of a manual option.
As mentioned a lot of times in other threads, other cars have rear mounted manual transaxles such as the Corvette's from the C4 on.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
