  • Replies 94
when i was little i remember watching a Japanese show, and they were showing an r32gtr, fell in love with skylines ever since, the r33 came out and i told myself i would work all my life just to have a skyline , and now i do :D
american muscle cars :D
one of my favourites was the late 60's camaro
that is the shit. Camaro and challengers FTW
oh and black trans am's....smokey and the bandit stylez.
suzuki cuppocino?
holden astra?
Ford capri?
:thumbsup:
/ghey
well in my younger days i didnt really care what type of convertible it was as long as it was red.
i now drive a black miata. =p
the lambo in cannonball run FTW
same (at the time)
my hero cars in order of when i drooled over them
Lambo Countach, Ferrari F40, R32 GT-R, McLaren F1
(at least i've owned one of them now :thumbsup:)
Yeah someone above said the bond cars. First car i really noticed was the aston from Dr No. Had a little Corgi model lol. Had a countach and a F40 too. Then it was the late 60s dodge chargers, because they're just so awesome.
suzuki cuppocino?
holden astra?
Ford capri?
:banana:
/ghey
judging by her name "carmen" her little comment "I pwn boys" I'd say she's a girl.......which really explains the hero car being a convertable. So gay doesn't really apply....unless........well let's not go there.
Miata.......must be american.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
