  • Replies 3.9k
Posted Images
well you could well be right. I do have a little fear inside telling me that after years of being handed sub-par cars and driving them to above par results he may not know what to do with it if he finally got a decent ride.
yeah vettel hasn't exactly covered himself in glory when it comes to keeping his nose clean. webber wasn't too flatering either after fuji... it cracks me up jsut thinking about that interview when louise said "ummm thanks for that mark"... haha.
well, they are professionals, I'm sure they'll put it behind them and move on, not like holding a grudge can get you a WDC anyway. I just hope webber doesn't throw away good opportunities when they present themselves. I hope Brunno is a nice guy, just like his uncle was.
If they do i will be pissed off. The guy hasnt been that impressive. The day you start flooding F1 with guys just because they have a name or won a lower series because that particular year was weak, well. I think Red Bull need to man up and get Klein a seat again. I think he hsowed enough, and has continued to show enough to be worth a chance alongside Seb. Which is another thing, i cant believe they are talking about canning Seb already?
Well its just feckin kids isnt it?
Qualifying has started. If you cant get a stream download TVU from http://www.myp2p.eu/softwareitem.php?softw...p;part=software and stream the SpeedTV channel from http://www.myp2p.eu/broadcast.php?matchid=...amp;part=sports
kimi... dude... wtf
My thoughts exactly. I was beyond tired when I watched qualifying on channel 10, and was struggling to keep my eyes open through Q1 and Q2, so was looking forward to my head hitting the pillow the moment Q3 ended. That all changed when I saw how bad Kimi went. I was losing it. Lets hope he can redeem himself tonight, but it looks like Louise is going to be the outright leader after tonights race.
Is it just me and my TV or did the cars look about a meter wider from behind in the qualifying coverage?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
