Hi all. As the topic states I can't figure why my car is idling high.
This is all the work that has been carried out engine wise to help you guys out with a solution;
- Plenum (standard) was removed and replaced to have it powder-coated.
- Throttle bodies may be been cleaned but I don't see why the mechanic would do it without charging me for it.
- Throttle bodies may have also been wrongly adjusted.
As far as I know there are no air leaks.
Where should I start with this? So far I have taken it to a normal mechanic and a performance place. The performance place was Chasers. They did an excellent job on everything else but could not identify the problem.
Any relevant input would be greatly appreciated. Please don't hi-jack the thread. If this problem is posted elsewhere and I didn't search properly please let me know and i'll contact a mod to have it deleted.
Thanks in advance! >_<
I have had exactly this problem.. the culprit.. the power regulator to the cold start. I took it to racepace and they spent quite a long time finding it (but find it they definitely did). I assumed it was the cold start itself, so we replaced that first, but the same symptoms appeared after a short time. It wasn't until the power regulator was replaced (which from what I gather is in a very annoying place), sorry I can't be more specific than this.
they may well have been cleaned while the plenum is off, they are right there so it might have seemed like a good opportunity.
you should be able to see if the throttle is adjusted incorrectly (could be but probably not) do they close right to the stops when no pressure on the accelerator?
all vaccum lines reatached properly? did a line maybe come loose when removing/refittting the plenum. do you have a boost guage thats T'd into one of the lines that may have been pulled off during plenum work, and missed because its further down one of the vaccum lines and not plumbed to the plenum itself?
Hey guys thanks for getting back to me.
Sarumatrix - the culprit.. the power regulator to the cold start. - I will look into having this work carried out, thanks for the tip. Neither of the mechanics I brought the car to mentioned this.
Duncan - they may well have been cleaned while the plenum is off, they are right there so it might have seemed like a good opportunity. - Thats what I'm thinking. From what I can tell, the throttle bodies are closed off completely. But I will definately check this thoroughly asap.
.....I really need to learn how to quote.
VB- - all vaccum lines reatached properly? did a line maybe come loose when removing/refittting the plenum. do you have a boost guage thats T'd into one of the lines that may have been pulled off during plenum work, and missed because its further down one of the vaccum lines and not plumbed to the plenum itself? - I have an aftermarket boost gauge t'd into the vac line right next to the box on the firewall. Boost is showing exactly what it should (12-13 pound). Is there somewhere else I should be looking?
Thanks for your input so far, it is much appreciated!
Edited by FVO
Pretty sure this is the cuplrit. I recall a thread a few weeks ago where it was decided DO NOT CLEAN THE THROTTLE BODIES. Nissan put a special coating at build time, and cleaning removes that coating, allowing sufficient air to leak past and cause high idle.
I read the same thread just now.
Next question is, what do I do?
  • 1 month later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
