cardio and the right diet would be more effective.
yer im very skeptical bout this kind of stuff...
but the reviews ive read are really convincing while others ppl say its not that great.
just wondering if anyone has had it/taken it? and what they rekon?
there is a health food store near me that sells it ..
its really only the caffeine in it that helps though ... it helps to raise your resting metabolic rate
when I diet if I want an extra edge I use no-doze caffeine pills ... you can get 100 for like $20 or less from your local chemist ...
pop 2~4 b4 cardio and 2~4 before you push weight and you'll notice a big difference!
finally a helpfull post....
oh ok thanks mate, will try that :blink:
cheers
*thread close*
However if u want an even bigger edge go for the no-doze plus..theyre a bit more expensive than normal ones but they give u a whollop of energy :domokun:
Edited by vinnie34gtt
lol @ using caffine pill in place of an energy supplement... (no-doz ftw!)
ive been using bsn no-explode as an energy supplement...thats some crazy stuff aye.
so i take it noone has used it lol
I had good success with the EAS 'BetaLean' product back in 2005... They don't make it anymore but they've replaced it with something else..
'Dynamx' or something like that... I'd reccommend it, but you need a good diet and adequate exercise to go with it...
Gaspari nutrition has one called Cytolean, is the best iv found atm, tried hardcore, lipo 6, tried to get a new lipo 6 product in but customs took it :thumbsup: next time il be going ECA, see how that works.
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
