Yes your bulging discs are doing a great job of that. Strengthening doesn't fix bad form, correcting with proper technique does. I'm not avoiding any weakness here...the back and core get worked just as much in my method, only less susceptible to injury because it's a stricter movement.
My 2c on this one for what it is worth , from past experience.
You have a point about stabillity, thats why sitting or bending the knees with a relatively lighter weight is a good place to start in terms of 'balance'.
However, once you are over a certain weight (body weight for sure) you basically need to have lots of stabilisation all the way up. So legs to core to shoulder girdle ,even wrists. Each of these should not be troubled and totally up to the task before going crazy. They are supporting muscles so should have more than you need to balance and stabilise as the shoulder press should not be used to target them.
Even if you bend your knees or sit, not enough shoulder stabilisation or core strength will see you get an injury with bigger weight.
However , I think where Ghosty and Husky33 are comming from is; once you are lifting strong across those areas a bodyweight press with locked legs won't trouble you.
In the mean time, best practice is as you said ' slight bend in the knees' or sit down and for the safest plan use a lighter weight if you don't have the confidence to press.bodyweight yet.
Edited by rev210
160 as of tonight! And weighing in at 79.7kg...that's double bodyweight :D
165...somebody stop me! Head started spinning as soon as I locked it out :S
Gotta run out of steam soon; at this rate I'm adding 10kg per week.
My back injury wasn't caused from MP, it was caused from overzealous DL'ing with bad form, which in my defence, I was fairly new to lifting back then and lacked the experience to know better - some of us just have to learn the hard way unfortunately. Hindsight is a wonderful thing...
Generally yes, but also no. Correcting technique doesn't automatically make you strong, you still have to train... and think about what 'form' is for a moment. Correct 'form' is generally the most efficient way to perform a movement or action, that doesn't mean it is automatically safe, for example, if a novice overloads the bar and tries the lift with "good form", injury may still occur because they are weak. On the flip side, doing movements in "bad form" but in a controlled manner to build strength in compromised position/less-efficient movement, aids in strengthening the movement when done in correct form, for example, "good mornings" to assist squats etc.
I disagree. CBF explaining why but as a simple test, try and do your seated press weights standing and tell me which is harder.
I don't do seated press, I do standing behind neck shoulder press...with split legs and knees slightly bent. My back stays strict throughout the whole set and I do 50kg x 10 for 3 sets + 55kg x 6 for 3 sets, so not that light.
that's light
Hey, I probably couldn't do 60kgx10 atm, but i will be the first to admit that it is light. And the only reason it is light is because i don't train it as much as everything else, like yourself, and 99% of people.
It's actually pathetic when you look how much higher my bench is.
it's not light for the conditioning goals you have but, it's really quite light if you are talking a standing press at your weight. Again only relative to people who care to lift heavy as their goal.
I'm sure you could train to do heavier if you wanted to but, you are doing what is best for your goals. You don't need to shovel huge weights on the shoulders without good reasons anyway.
I was the same up until 165kg lol, that was my figurative brick wall. I think my grip failed on 170kg at the same point I couldn't really complete the lift, and have only attempted it once.
Good work Birds, keep dat shit up!
It's not light in that the potential for injury is very much there should you use bad form, which is why I brought up what I lift for that exercise in the first place. It's like a 100kg deadlift - nothing in the scheme of lifting and what people are capable of, but you can still do a lot of damage if your form is out.
For someone with a spinal injury, that's a great lift! My grip felt like it had more in it, but 165kg was the first time my back had to put in a lot of effort to get the weight up / started running out of steam. Grip seems to be fine for 1RM stuff, it's the sets of 10 where sweat builds up and resetting my reps turns it to shit, even with much lower weights.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
