Its just the path that goes right around the lake, can take a couple of diff ways. Can be between 2-3 and a bit km.
Opinion need,
Protien.... carbs and fat not too much of an issue, lost 12-3kg so going to slowly put mass on.
either:
SCIVATION WHEY + XTEND COMBO which is 99
or go with dymatize elite whey 89.
both 2.26kg
jeezus krist man.. so maney misstayks in won sentance.
You better get some powder quick. otherwise each curl you do will just take a bite out of your bicep muscle.
Yer mate i rush and im first to admit im not the best at vocab. Could not get me talking in front of a crowd, many issues.
Opinion need,
either:
both 2.26kg
www.bulknutrients.com.au
Try standing naked in front of a crowd, that'll fix your public speaking phobia.
Yer i hear some good things about there products.
Jocks id be able to do, just no speaking :P I start saying something then pause lol
No jocks, completely naked.
I go the 10$ per KG at butcher of chicken breast, I do struggling to get to 220g
You actually have trouble hitting 220g of protein per day without supplementing? Not too long ago I got in trouble for exceeding 300g per day and that was with only 1 25g serving of powder most of the time lol
This.
Stop subliminally bragging :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
