I did have a wardrobe malfunction during an ass to ground movement lastnight...I'd like to think the sheer awesomeness of my hams and glutes cannot be contained by mere shorts. The reality is closer to...squatting in 10 year old board shorts is not a good idea.
lol cheers guys
yeah mid 70s is prob a good weight just gotta lose some fat, clean up diet a bit (and really need to stop my drinking on the weekends..)
and yeah the 90 was a max set not for reps unfortunately, i'll get there though!
Birds squats, squats so much he rips shorts :P
wouldnt even worry about weight as a figure. clothes size and mirror is a better guage.
you know what you have to do then.
This...
Weight figure...as far as aesthetic goals go...is only really useful for monitoring diet once you've reached your goals and are very familiar with your normal weight fluctuations. Other than that, an honest look in the mirror is the best tool.
Is it weird that you'd rather work out/train rather than going out on the piss?
Nope, both are addictive and both will get you ladies...but only one will guarantee she'll be good looking the next morning :P
This...
yep, as long as your strength is increasing and weight is staying same/decreasing youre doing something right.
For those that take pre-workouts, have you found that you are more susceptible to muscular injuries or even twinges, particularly when making quick movements ie sudden changes of direction or sprinting etc??
Not preworkouts fault. It's called getting old. Even young people get hurt when making sudden changes or direction when moving fast. The older you get , the more the joints and ligaments complain about it.
If you get a twinge or an injury just drink beer afterwards, although I heard that breakthroughs in research have found that squats are the best cure.
I only have been training for a bit but I just love it, doesn't matter how tired I get, how my body doesn't want to move/punch/kick but damn it's so hard to explain.
Your body doesn't want to punch or kick or move?
Show it who's boss.... and squat.......
...........like a boss.
I should of put more clearly after a few sessions on the thai pads and leg kicks i'm exhausted and my body doesn't want to move my mind still wants to keep going.
I'm not sure about that lol yes definitely getting old and that doesnt help, but have taken pre-workout 4 times when playing cricket and 3 times resulted in strained hamstring, all when really making quick movements. Have played since I was 10 and has never happened any other time, only when I took the pre-workout. So dont take it anymore for cricket.
Well, they are a pre workout after all.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
