I have an extremely high tolerance to pre-workouts or in general...stimulants etc.
I tried Craze for a while but needed 4-5 scoops to really feel it. This is coming from someone who was using 200mcg of clenbuterol each day and eventually became completely immune to it as well as DMAA. So instead I simply finish work, train than eat some good solid carbs and protein. For almost 2 months I haven't had any supplements whatsoever. Old school is the way to go :)
you've definitely changed your opinion then...
Here is a thought to consider. I make some assumptions here so take from it what you will.
How much do you rely on the stimulant pre-workout to give your best effort in physical performance?
If you are saying you don't do as well without one, then you are likely not even close to your limit.
Not trying to sound too harsh here but, It's a mental crutch. You are waiting for some kind of buzz to tell you it's now ok to pick up a weight.
You are the one lifting the weights when you are taking it, not the suppliment. Once you realise that ,you can pocket the money and buy some beer on the weekend with it.
Funnily, we're talking about PWO supps being a waste of money with regards to fitness....so instead you suggest the consumption of alcohol? hahaha :P
Good point. They are both un-related to fitness, except one pretends to be and isn't.
Edited by rev210
Didn't know clen had a pre-workout type effect?
Used wraps for the first time since August last year for squats...
man.. don't miss that pain.
and that was with half arsed wrapping.
good rebound though.
and the tightness gives a nice secure feeling when you look past the burning pain on the back of the knee.. lol
Never if you don't need to.
I've only done a best of 150kg for 3 sets of 5 squats without wraps.
Program had me doing 145 last week and 152.5 this week
so I started using them this week and will keep doing so till the comp in April.
I think you get used to them after a while... just like your hands get used to deadlifts.
I've seen blood on some peoples legs before and lots of bruises.
I had Scott at PTC Brisbane wrap me once leading up to last years Nats.
he goes, how tight do you want them?
I told him to go easy first time since I'm used to wrapping myself.
He goes ok I'll go about 50%
This 50% managed to get 2 extra loops around the knee then when I wrap "tight" at home myself..... It hurt like hell.. lol
And my wraps are the 2 meter ones which are well used Inzer ones.... compared to the 2.5 others use.
Hopefully I'll better my last PB at a slightly lighter bodyweight come April.
Going back on SS until I hit 180kg dl, 140kg squat, 100kg bench. Didn't feel like I was getting anywhere on the other program I was on, progression felt too slow.
I have been on the same program for about a month now, lifts have improved but my biggest issue is the gyms weight. I have to go up with 2.5kg increments rather then the 1.25 that is suggested.
Have plateaued on bench already at 60kg which I am trying to get past. Always sucked at bench for some reason, always get to 60kg and struggle to go up any further.
Weak shoulder girdle muscles is the reason. I can tell you that a good way (other ways get there too) to get your bench max up is the following ;
a) stop doing bench press
b) Start doing work on your shoulder,.scapular and rotator cuff strength and flexibillity.
c) Gradually incorporate strict press movements
d) when you can do your bodyweight on a strict press then you can think about bench press.
e) You are only allowed to 'think' about bench press until someone shows you how to do them properly, then you can 'do' them.
Do something like this and that plateu is going to be history. Also you are going to have much better muscle balance and less risk of injury as the weight goes up.
Edited by rev210
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
