The problem I currently have is that my mind is ALWAYS telling me to eat - even when my stomach says it's full.
So you have the fat person version of "I can't gain weight". Conversely, you need to feel that hungry feel. The more you feel it, the more you lose.
Hungry? Have a little lunch. Still hungry? Good, don't eat anymore for a couple hours.
The problem with most skinny people, who say they eat and don't gain weight, is that they eat when they are hungry. If you're trying to gain weight, you should never have that feeling. You should be constantly supplying food to stave off feelings of hunger. If you are hungry it means you failed.
So have lunch...you're full...an hour later you're not even hungry...but you eat more food just because you can. Load yourself with carbs.
This ^
I started out at 65kg and peaked around 93 or so after always saying "I can't put on weight".
In the end I ate 6 meals a day hungry or not, lots of carbs and protein, destroyed maccas etc, was worried about fat but because I was gyming all the time it wasn't an issue.
Was also the first time tried supplements and I was just using sustagen sport and plenty of it.
Now that's a turned into good eating habits where I eat 5-6 times a day, just not as large a meals and I maintain my weight ok (86kg).
I also think that a lot I younger skinny guys with fat metabolisms have better success in the mid 20s instead of early 20s as the metabolism slows down a touch.
My 2 cent from a formerly skinny guy :)
It drives you crazy when it's not just the usual "oh what's that stomach, you're hungry?" Deal. All I think about when I'm not busy is food lol
Try eating 13 slices of pizza, a garlic bread and large chicken parma :)
I was full for 5 hours but hungry afterwards hehe. Not to mention the amount of times I went to the toilet...
After eating super super clean for quite a long time, I had to enjoy myself with some real food
Easily. Last night was 1 cup rice with 300g kangaroo mince, then about an hour later an entire crust meatball pizza, then a touch over 1 cup of oats with a heap of prunes and dried apricots and a scoop of chocolate casein. Then I finally just fell asleep before I decided to try eating more.
Did you calorie count that Troy? lol
Hey guys does any 1 still have the old jac3d they are not using ! . I can not get anything out of this new stuff! tried stacking it with creatine . just not the same . even backed my bench press wait down and just pist off the kilos since this new shit came on the market! not fair they are still charging the same price ! :/
That sucks bro, are you gonna try sell your gym membership on gumtree now that you can't train?
Hey Mike Ye can still train mate but its Just slow going and tedious atm. Pushed up my hours. but fatigue is setting in quicker. Will Just push through it though.
After losing weight quick I've upped the amount of shit I've been eating again. Problem is I eat way cleaner than before so still losing weight :angry:
Still don't really mind losing that little bit of fat I had
Edited by UNR33L
losing weight is not an issue at all if its fat?
What the f**k is even the point to that ?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
