Haven't been eating properly due to working like a dog.
I need to fix up my diet and get my passion back, I've still been training, just weights, no cardio, trying to maintain what I have, but my bodyfat has def. gone up due to poor diet. Good thing is the muscle is still there as I haven't lost strength. Bad thing is I now have a 36 inch waist to match lol. (I'm normally 34).
Stick to the basics and slowly lose fat or try a quick fat-loss diet to see some quick progress for now...?
Edited by IOWNU
If I've got a light inner quad/groin strain from squatting is there anything specific should be looking to improve in the form?
Does this mean my stance is too wide? I'm outside shoulder width as that's most comfortable on my ankle. Feet about 30deg.
From what I read its about poor hip mobility and I have had tender hip flexors for a little while.
I sit all day so no surprise.
If its on both sides, it's likely a flexibility issue with the adductors. Stretching hamstrings/adductors can help. As can more squats.
One good stretch for them is to stand with legs really wide apart and slowly straighten them...or stand with legs straight and slowly move them out until you feel the slight pinch, then hold.
It's just the one side and I was already doing hip flexor stretch, walking spider man, etc, I may just need to do a few more and be careful when it's cold. I have slacked a little with my stretching, it was daily, now it's just on workout days so I'll pull my finger back out.
Thanks for the stretch suggestion, I'll add it in.
I'm gonna go awkwardly foam roller my groin...
whoa whao whoa..... you can do that with a roller now?
http://www.mobilitywod.com/
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
