Bought some BN WPI natural and vanilla.
The natural flavour tastes like powdered skim milk but ok if you make smoothies with it. The vanilla has a very faint taste too it. Definitely would choose ON in the flavour department for an extra $20.
I can see where you're coming from - the vanilla isn't really a strong flavour. I like it because it's simple and has the highest protein percentage, but I do agree the chocolate is much better! Banana isn't bad either, if you like the fake banana flavour haha
I'll grab BN chocolate next. I prefer paying cheaper and taste isn't a big thing for me anyway as i only have it once a day. Was just giving my thoughts for others who may not have had those flavours.
If I am doing a bike ride in the same day I am doing a PPP session I add a schoop of chocolate icecream to my shake, because I am a disgusting animal.
I use BN vanilla.
Edited by Nee-san
Dan I WAS paying $50 for 2lb of ON Gold Standard, til I started having 2 shakes a day.
If I were to get sucked into the bro marketing of the local supplement shop, I'd be paying ~$80 a kilo for Max's or Dymatize stuff!
Yeah the BN is $100 for 5kg of WPC.
I bought some fitbodies protein off ebay, $85 for 4kg. Serve size 30grms - 27grms protein, 1.2grms carbs and 0.8grms fats per serve. Chocolate tastes very good, better than BN. Mixes well with no clumps but does froth up a bit.
Little dubious on the protein claims and I'm sure the scoop is slightly bigger than 30grms but if taken at face value it's a very good protein at a terrific price.
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
