Yeah I do workout at home, and I don't smell that bad, it's more that over time the shirts build up a bit of odor.
Singlets are the go for summer.
Plus I'm thinking of this doubling as my running shirt and in the warmer weather I wear a shirt to protect me from sunburn (milky bar kid).
My 2XU tights give me the confidence to do all the things I want to do, like horseriding and vacuuming and preparing sandwiches, without those embarrassing interruptions from mother nature.
Hmm, do you wear them in the gym or running (or both).
I'm in two minds about wanting to help support my ankle while I run, squat and DL, and not wanting to offer it too much assistance.
The physio said I may need to come to terms with the fact that it will never be 100% and I'll always be making some form of compensation for it and that using things like socks or self massage etc may need to become part of my "routine" to manage it.
I don't run. I generally wear them on leg days.
Self massage/massage should be apart of everyone's routine IMO.
Markos two questions.
1) Can you show me what you consider good bent row form.
2) Given the rom issues i'm having with my ankle and how it affects my squat mechanics, do you see issue with me using a 10mm or so board under my heels?
Okay, I'm rowing now, see how I stay down and pull the bar to my belly not my chest, perfect form, I have 140kg on the bar and I'm knocking out 8's
I recommend the heel, but proper footwear (heeled lifting shoe) is much better, around $120
  • Like 1
went to the premiere of Pain and Gain at the local cinema last night, nearly the entire audience was the swole guys from the gym who also lift 5 days a week + the "natty" bodybuilding crew from the other gym. Good movie, was surprised to see compound movements featured a lot, 10/10 lols
I loved pain and gain thought it was an awesome movie
it came out in the US months ago - I chose to wait for it at the cinema here rather than watch a crappy cam version.
weighed myself again, still at the same point as the last 3 weeks or so, given recent diet and training changes I'll check again in a few more weeks!
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
