Yeah I do workout at home, and I don't smell that bad, it's more that over time the shirts build up a bit of odor.
Singlets are the go for summer.
Plus I'm thinking of this doubling as my running shirt and in the warmer weather I wear a shirt to protect me from sunburn (milky bar kid).
My 2XU tights give me the confidence to do all the things I want to do, like horseriding and vacuuming and preparing sandwiches, without those embarrassing interruptions from mother nature.
Hmm, do you wear them in the gym or running (or both).
I'm in two minds about wanting to help support my ankle while I run, squat and DL, and not wanting to offer it too much assistance.
The physio said I may need to come to terms with the fact that it will never be 100% and I'll always be making some form of compensation for it and that using things like socks or self massage etc may need to become part of my "routine" to manage it.
I don't run. I generally wear them on leg days.
Self massage/massage should be apart of everyone's routine IMO.
Markos two questions.
1) Can you show me what you consider good bent row form.
2) Given the rom issues i'm having with my ankle and how it affects my squat mechanics, do you see issue with me using a 10mm or so board under my heels?
Okay, I'm rowing now, see how I stay down and pull the bar to my belly not my chest, perfect form, I have 140kg on the bar and I'm knocking out 8's
I recommend the heel, but proper footwear (heeled lifting shoe) is much better, around $120
  • Like 1
went to the premiere of Pain and Gain at the local cinema last night, nearly the entire audience was the swole guys from the gym who also lift 5 days a week + the "natty" bodybuilding crew from the other gym. Good movie, was surprised to see compound movements featured a lot, 10/10 lols
I loved pain and gain thought it was an awesome movie
it came out in the US months ago - I chose to wait for it at the cinema here rather than watch a crappy cam version.
weighed myself again, still at the same point as the last 3 weeks or so, given recent diet and training changes I'll check again in a few more weeks!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
