how does everyone keep track of their workouts?
I use the Jefit app on my phone, keeps track of all my logs and lifts, can add notes if I feel the need and has made it easy to keep track of my workout volume.
Simple notepad file on tablet.
I run endomondo also to keep track of time spent and rest periods and check email, facebook during breaks and sometimes youtube clips on form.
I'm at home though so using a tablet to play my music and record notes doesn't seem as nerdy when you are flying solo.
Deadlift 220kg Birds. In your next deadlift session.. Do it once at least & receive a virtual high five.
You will do it ha ha...
No seriously lift 220.... I am confident you can do it.
Hahaha. Right now I'm confident I could get 200 up; I don't want to try it though, cause my form will be terrible. I'm currently fixing my form with more volume at lower weights for now, as my lower back was getting a bit sore with my "yanking" as Markos calls it.
Also want my squats to catch up, because they are far behind my deads at the moment. But soon I'll return to the deadlift 1RMs and I'll definitely give 220 a crack! Tough ask for a tall skinny 80kg not going to PTC :P
I used to have just a generic diary and would scribble shit down in there, but now I just use a very basic notepad app on my phone. Only really need like 2 weeks of notes at any time to skim back through anyway.
Lunges are the worst torture known to man. I'm properly struggling to stand...squats never did this to me!
They just have this ability to extend the set beyond physical pain and it becomes all about how much you can put up with mentally.
Yea walking lunges say.....for a about 20-30 meters with lots of weight on a barbell on your back is the worst kind of pain especially after the half way mark where you just want to give up because of the intense burn. Not to mention the nice cardio workout that comes with it. I do them twice a week and have developed excellent shape as a result. Squats had sliced my lower back in two so utter fail for me :(
Eating peanut butter
This. lol. And incline leg press (plate loaded). Got up to 360kg for my working sets, so at least I wasn't being a bitch on the thing.
Looks like my ROM issue through my shoulders wasn't quite as bad as I thought, since it was pointed out I had the bar way too low anyway haha...so now that I'm resting it in a more appropriate position as well as stretching my chest/shoulders/etc beforehand, I can do barbell squats again.....my traps are f**king obliterated though, not used to having weight resting on them >.< will get used to that though.
Best part is 100kg feels like nothing! (inb4 that asshat Markos pointing out 100kg IS nothing :P). Should be back up to a more appropriate weight in no time. Will increase 5-10kg for the next couple of sessions, then 2.5kg every session without fail from then on.
Markos, I remember you saying not long ago that nothing you see amazes you anymore. I'm curious: what's the most impressive or amazing thing you've ever seen with regard to lifting?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
