It'd quite a strict movement; one of the reasons it is done behind neck, because there is little variance in the range of motion. As long as you're taught and execute it correctly, this makes it one of the safer shoulder exercises. But no amount of safety in a range of motion will save you if not everything is sitting right when you do it.
Sorry birds thats not right at all . The range of motion and the position is bad compared to standard. It's got far more stress on the rotator cuff due to the position of the shoulder.
You can do them in relative safety, provided you are in correct shoulder position (and can get there with enough shoulder mobility).However, It will place much much more stress on the rotator, scapular and traps than front style. Maybe people don't like the regualr military press as much because sometimes the amount of weight they can do is less , relative to behind the neck (people like bragging rights). Add to this the 'standing' as opposed to sitting component and it's easier to get it wrong.
To help illustrate as to why these are strong on the rotator cuff , look at the elbow position. In the same way as the other pressing movement bench press. elbows out for gym punter bench press (ouch my rotators) vs the elbows in version for powerlifting.
Front press starts with the elbows in front and in. Moving the bar upwards vertically. Behind the neck is out to the sides and up out a little.
Either press needs a good strong shoulder girdle and upperback. Both assist slightly in actually building stronger supporting muscles as a compound movement. But, that aint enough.
My shoulders are pretty strong, I didn't need them.
Edited by rev210
liquid grip is great for gyms that don't allow chalk
f**k those gyms lol. Just don't let them see you start using it, and don't make a bloody mess....then if/when they notice you've got chalk, they won't usually care since you didn't get it everywhere haha
Either way, f**k those gyms :P
Also, fellow protein brahs...a testing company finally got back to me and are emailing me information on how to send them a sample. So the wheels are in motion
250x188xthe-visa-picture.jpg.pagespeed.i
Quoted for truth
I think it's more that some gyms (all of which would be commercial gyms) would get up you for leaving a mess lol...I know the chick at my gym was like "don't make too much mess or the cleaners might whine haha"...she cool though.
I just dont want to end up throwing up my food :)
You won't if you eat at least 2 hours before you work out for a large meal, or an hour for a small meal.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
