i dont normally take a pre workout simply because I have never noticed a difference in the past when I have taken them.
only gave this one a try as the guy gave me a whole bunch of samples.
didnt read into the marketing. GAT does market a bit like that, but I have read good things about their products.
end of the day it was a sample, I gave it a go and first test was a good one. I have 3 or 4 more samples of it which I will try and report back on.
so these are the claims;
1)SUPER-INTENSIFIED ENERGY*
2)CLINICALLY PROVEN PRO-TESTOSTERONE*
3)REACTIVE HYPEREMIA (MUSCLE PUMPS)*
4)DMAE INFUSED, MIND-IN-THE-MUSCLE FOCUS*
5) ROAD MAP VASODILATION*
What it actually means
1) It's got some calories
2) Doesn't raise testosterone beyond normal or at all in the case of a healthy person (hence not illegal)
3) So what
4) placebo
5) Only applicable if you are lean. If you are a juiced up body builder you have what you need already.
yet another 'short cut' promise that tastes like apples.
3) So what
4) placebo
In my experience with Bulk Nutrients' Cognitone PWO, DMAE is more or less the only thing in it that I notice a very distinct benefit from. It's just another analogue of DMAA I believe, and DMAA gave me a very noticeable increase in mental focus....so I guess I'm saying in my opinion, it's far from a placebo.
Like t-boosters. Most only raise your test by 42%. An increase of well over 200% is needed for any real muscular results
I disagree Tom, please stop spreading unfounded misinformation like this.
They raise it by 48%. Get it right.
  • Like 1
dollar for dollar, injecting test would be much cheaper when actual effects are concerned lol
Step 1 - engage in dat dere sexy time 5 times in one day
Step 2 - go to doc, say you can't get it up, request blood test to analyse t-levels
Step 3 - t-levels come back lower than normal (yeah you knew this would happen; inb4 sabotage)
Step 4 - get prescribed test therapy and reap the reward of dem gainz for cheap
might as well cut to the chase and start pinning.
Speaking of which, do pro powerlifters use gear? Probably a Markos question, not judging, genuinely curious.
In an untested federation? Probably. In any competitive environment where people devote their lifestyle towards a cause, you can be sure people will be doing everything they can to get the best out of themselves and get an edge on competition. People do it in tested environments like the Olympics; I don't see why they wouldn't in a situation where it is legal. I would if it was my sport.
Every 2nd guy (ok maybe 3rd guy) in my gym is on the gear. Most are happy to admit it too, although its pretty obvious on most. That's in an environment where not many care about what you lift.
I can assume in an competitive environment where testing is not as prevalent the use of the stuff would be frequent. You can get it from anyone nowadays and that makes it even more widespread.
Although its a shame and a sign of the times when whenever there is someone who looks well built or lifts big people assume steroid use...
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
