I'm assuming if you're doing 170 for reps then it's not really close to your max effort. Maybe that was his point?
Either way, people need to learn to stfu and pull their heads in.
Max effort need not be a 1RM, my friend. It can be the last rep in a set. It can be the last set of an exercise where you are already fatigued to the shit.
I reckon it is. Minor things annoy me but rarely will a gym be perfect for what you want and by the sounds of it I have things better than most.
For the first time lastnight, I had someone approach me about my deadlift form. He's a membership consultant there and he approached me saying "I...I gotta say something man", shaking his head a bit. I said "What?". He says "You're going to end up injuring yourself, your back is arching when you deadlift." I was doing 170kg for reps, so I explained to him that when you're pushing close to your max effort, form will never be perfect. He says "So you don't think form is important?". I reply "No, don't put words in my mouth; form is very important, but if your form is absolutely 100% when lifting with maximum exertion, it likely is not your max effort. I've never had an injury from deadlifts and I could show you an 82kg lifter who can pull 290kg without injury and his form won't be "perfect". I appreciate your concern, but I disagree with your logic". He said "Alright, I'll leave it be, but..." and laughed to himself.
Next minute he's doing some cable exercise and I hear him complaining to his training partner about his back hurting..,wtf? Should have told him to lift the 170kg I doubt he could have even done one of them lol
haha was at the gym yesterday with John and he took out his headphones only to hear the dude talking shit about this same story still :\
on the cables with his mate standing around brah :P
he does have a decent physique at least, better than being told off by one of the skinny kent PTs
Edited by UNR33L
at least the guy was showing concern for your safety instead of just potentially letting yourself get into snap city i guess.
Yes which is why I'm always polite if I disagree with advice. Have had people tell me I'm lifting too heavy on lat pulldown etc. It's tough not to assume they're saying it because they lift significantly less and it's their way of dealing with the dissonance that someone smaller than them can lift more. So I usually give benefit of the doubt.
Haha true. His physique isn't that good, he's just 5 ft tall and looks wider than he is. Dude can't bench more than 3 of his own bodyweight, which is one of the reasons I didn't listen to him.
Another is that I've seen him rock up to the gym on a motorbike wearing no safety gear, save for a helmet. And Jon overheard him saying he doesn't deadlift because a motorbike accident prevents him from doing so. Obviously knows how to take care of a back.
Another is that I've seen him rock up to the gym on a motorbike wearing no safety gear, save for a helmet. And John overheard him saying he doesn't deadlift because a motorbike accident prevents him from doing so...
So it's quite clear this guy suffers from extreme ignorance lol
So my friend at the gym got told off straight away tonight for using too many plates on the leg press...
He's thinking of driving to Perth (4 hrs there and back) every night to go to Musclepit.
However there's a guy in our town who is looking at starting a powerlifting gym, and this guy wants to go there obviously. I was asked tonight if Id be interested in joining once it's up and running.
F*** a four hour trip each night. I'd buy weights to use at home.
What. The. f**k
im expecting this in the next month or so
6 plates off being able to use all the 20kg plates.....
How many plates is this? lol
If there's one thing I HATE about leg press, it's having to load 16+ 20kg plates onto the f**ker, then back off again when I'm done. Use more energy just setting it up than doing the movement!! haha
What. The. f**k
Haha I'm up to 4 20kg plates on each side...
The guys usually help me put them away though ha
That's more than I see most guys doing :cheers: lol
Yeah I've only just got back into doing squats again since ditching them at the beginning of the year or thereabouts. Much more effective, and as you said saves a lot of time loading plates lol
Yeah I do squats and leg press. It's annoying when I fail on squats though because I have to take all the plates off and then back on :/
Leg press is the worst. They should just make one with some sort of quick change pin setup and have a decent amount of weight on it. I used to load 36 20kg plates on and off , at least that gym had plenty of plates and didn't care.
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
