hahaha dont think i could afford travel costs for him to tour NSW :P
good on him, if i could do something like that as a second job to earn more coin i would. But i'll assume pasty skinny white boys with no dance skills isnt in high demand for hens parties :P
Lol no partner
Have got a few compliments :turned:
Only really like this one chick who isnt into me so that sucks...
Guess I'm in the same boat, started gym to impress but now its like I'm just doing it because I have nothing better to do... Motivation really long gone, struggle town atm :/
I just
I just really want to take a whole loaf of bread, smear each piece with peanut butter and eat the whole loaf.
Repeat with 2 more loaves. :rant:
lol so do it man, nobody is going to give 2 shits. You will work it off the next session anyway, if you have no mad goals or aren't competing, don't punish yourself, it should be a fun thing to do, not a chore.
Edited by ActionDan
Yeh but was just to prove a point amongst friends, 6-pack is do-able without cardio. I def wouldn't work off 6000+ cals in the next session haha.
Yeah I did no cardio either
I can also confirm Birds like to take off his clothes. Gets unsuspectingly posted on my FB newsfeed
After stalling on nearly everything I have decided to cut away the Strong Lifts 5 x 5, doing cardio/cross fit 3 or 4 times a week (mandatory at work) and trying to squat 3 times a week drained me, my age (48) is my excuse and I'm sticking to it, LOL.
I have now gone back to my old routine with some minor changes.
All major exercises have 4 to 5 warm up sets from 10 down to 2 reps before working weight.
Current weights in kg follow sets and reps ( I have deloaded about 10%)
Sessions are all straight after work.
Critique at your leisure.
Monday
Bench 5 x 5 107.5
Inc DB 4 X 10 35
Dips 3 x 10 20
X overs 3 x 10 27.5
Tuesday
Clean 5 x 3 82.5
Shoulder Press 5 x 10 47.5
Superset of:
DB curls 3 x 15 12.5
Rope Ext 3 x 15 50
Wednesday off
Thursday
Dead 5 x 5 125 (Rubbish but working up)
Over Grasp Heaves 4 x Max BW
Arched Close Grip Heaves 4 x Max (I use the handle off the seated row over the ladder section of the heave beam)
Lat pull down 4 x 10 50 (used for the stretch)
1 Arm Row 4 x 10 35
Friday
Squat 5 x 5 107.5 (Rubbish but working up)
BB Lunge 3 x 10 40
SLDL 3 X 10 60
Superset of:
Ezy Curl 3 x 15 25 (without bar weight)
Skull Crushers 3 x 15 32.5
Saturday and Sunday consists of family stuff, cake, booze and enjoy life to the fullest.
My goal is to up my weights and see how I go.
All exercises are full range of motion (ATG and all that other correct form stuff, I am overly strict on this due to previous injuries, from me being a stupid dick).
One off the guys at work who does powerlifting has tried to get me on the 5 3 1 routine but it has to much math and shit, all I do on mine is up it 2.5 kg if I get all sets and reps.
If I stall again I will just deload on that exercise or do 5 x 3 for the main lifts and see how it goes.
Just got off my human growth cycle run whilst in Thailand. Had put on 5 kgs, ate 6000 calories, looked leaner and stronger. Now that I'm back from my honeymoon it's time to start a round of sust/deca combined with anavar. f**k supplements I say :)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
