Mate just add a few sets to your workout or do some HIIT cardio. People will tell you that you can't out train a bad diet, but it's not a bad diet if the calorie outtake is there too. I eat a loaf of bread a day and still have abs ;)
It's possible to burn more then what you eat. Lots of anaerobic exercise i.e. HIIT and weight training which burn a f**k load of calories and afterwards as well.
I'm a fan of devouring bread with pb, rice and enormous amounts of meat, chicken and pork.
hardly have any pics. But If you like I can post of one currently now and maybe once I finish my cycle or 12-16 weeks later?
Sounds good. You generally don't see many of these because so many people doing cycles aren't too open about it or are quite vague.
In fact I've only really seen before and afters of a mate at uni who did a cycle as soon as he joined a gym. Mind you he ended up the same size as me after 8 weeks and I had been going for a couple of years back then lol
I admit it because I've broken the natural pathway. No point trying to act like I've achieved my results on protein powder, chicken and broccoli lol. Someone can blow up quite rapidly whilst on something. Scary part is after you stop. Having all the pct possible is the best thing possible. Still can't avoid the inevitable though...Just gotta train even harder!
I think these days you get more respect from those who don't cycle if you're more open about it. Most people don't have a problem with it beyond someone trying to pass themselves off as natty or talking about their routine and forgetting to include their extracurricular activities in it, and will still admire the impressive feats that are a well crafted body or a strong lift. We all know that whether you use or not has nothing to do with your intensity/willpower/effort; only the extent of the results achievable.
probably mentioned earlier, but what do you guys use to monitor your intake?
keep a diary? phone app? if so which one?
I use these apps called common sense and a pinch test :P
Ignore the retard talking in this vid.... the details of Bostin Loyd and his 1 year steroid adventure is available on the web somewhere..
He publicly listed every single drug he took, the amounts and timing and blah blah blah..
http://www.youtube.com/watch?v=lxpCFMzmPAc
The gains he got over a year are awesome but he definitely wasnt small to begin with, just carrying a some extra fat.
I havent seen the video where he talks about everything he took, but i daresay he was on cycle year round which is pretty intense and thats probably got a lot to do with why he has managed to keep the gains.
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
