Mate just add a few sets to your workout or do some HIIT cardio. People will tell you that you can't out train a bad diet, but it's not a bad diet if the calorie outtake is there too. I eat a loaf of bread a day and still have abs ;)
It's possible to burn more then what you eat. Lots of anaerobic exercise i.e. HIIT and weight training which burn a f**k load of calories and afterwards as well.
I'm a fan of devouring bread with pb, rice and enormous amounts of meat, chicken and pork.
hardly have any pics. But If you like I can post of one currently now and maybe once I finish my cycle or 12-16 weeks later?
Sounds good. You generally don't see many of these because so many people doing cycles aren't too open about it or are quite vague.
In fact I've only really seen before and afters of a mate at uni who did a cycle as soon as he joined a gym. Mind you he ended up the same size as me after 8 weeks and I had been going for a couple of years back then lol
I admit it because I've broken the natural pathway. No point trying to act like I've achieved my results on protein powder, chicken and broccoli lol. Someone can blow up quite rapidly whilst on something. Scary part is after you stop. Having all the pct possible is the best thing possible. Still can't avoid the inevitable though...Just gotta train even harder!
I think these days you get more respect from those who don't cycle if you're more open about it. Most people don't have a problem with it beyond someone trying to pass themselves off as natty or talking about their routine and forgetting to include their extracurricular activities in it, and will still admire the impressive feats that are a well crafted body or a strong lift. We all know that whether you use or not has nothing to do with your intensity/willpower/effort; only the extent of the results achievable.
probably mentioned earlier, but what do you guys use to monitor your intake?
keep a diary? phone app? if so which one?
I use these apps called common sense and a pinch test :P
Ignore the retard talking in this vid.... the details of Bostin Loyd and his 1 year steroid adventure is available on the web somewhere..
He publicly listed every single drug he took, the amounts and timing and blah blah blah..
http://www.youtube.com/watch?v=lxpCFMzmPAc
The gains he got over a year are awesome but he definitely wasnt small to begin with, just carrying a some extra fat.
I havent seen the video where he talks about everything he took, but i daresay he was on cycle year round which is pretty intense and thats probably got a lot to do with why he has managed to keep the gains.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
