I believe there is a storage unit being auctioned off in Sydney tomorrow filled with ex-commercial gym gear/equipment.. Trying to get details, however my contact isn't being as forthcoming as he should! Lol.
So if anyone is interested, will post up details when I manage to get a hold of them.
  • Like 1
Pull ups and benching will usually suffice in the shoulder development department. If you're talking about "aesthetics", well, you're probably asking in the wrong forum..
If you are talking shoulder strength then pullups and bench arent going to cut it , unless you are wanting pretty ordinary abillity. Military/push press over bench any day. Balanced with external rotation movements to build strength through that motion. Thorasic spine and shoulder girdle strength are most peoples weak links.
Speaking as someone who used to do strict military press with more than 100kg for reps, including cleaning the weight (not off a rack)
Edited by rev210
agreed
You seem fairly knowledgeable in these areas rev, care to offer any insight on good ways to strengthen thoracic and shoulder girdle?
On another note, how do you guys stop your legs from bleeding doing deads? Long socks?
You don't have to drag the bar up your legs; you can pull the bar just in front of the shins etc.
Just give it time and practice...
Haven't had scraped shins for ages, but I used to get scabs when I was first starting out.
Socks / cup of cement, same thing :P
Haha doesn't bother me, but some people get worried if, god forbid, a drop of blood gets on the bar.
Curiously, if you can do normal deads how come you're doing Romanians?
Changed my training style a while back and these fit well into what I'm doing
I wear pants whenever I do deads, has helped but I still get bruising
mfw I have bigger calves than everyone in the gym apart from the 1 competetive bodybuilder and don't do any calf isolations at all.
regretting doing heavy db rows yesterday then heavy deadlift and volume squat today - lats and upper back did not want.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
