I also feel the clean and press is one of the best exersices out there, strangely hardly anyone does them.
It's a bit technical for most. I like doing them they are a good brute strength movement. I try to slow the clean down as the press weight is usually light-ish for cleans. This way I get more out of the picking it up phase. Not doing them at the minute ,I am lacking some flexibillityt. Wrist injury needs sorting too.
2yrs ago in my build section I was doing 105kg for 5 reps (don't know what it translates to as 1rm). I forget what I was doing 12yrs ago but, I was significantly stronger back then. Could have been 120kg for 5.
I am keen to see what I can progress to this time round , now that I am commited to a gym for 12months.
On tip I can give for this is not faffing around with other pressing movements like bench while you are training this. Ideally if you are 5 or less reps then this would be the only thing you press in that week (no bench)
Edited by rev210
TM7GTR I started on ICF 5X5 3months ago after no gym for a few years. It's been a great program for relearning form and the weights are getting seriously heavy now. Plus the accessories added in give those mirror muscles a decent pump too. I'm seeing good results in my strength. Check it out
Getting back into it after a long time off and surgery? I would hit the mobility exercises and band work, for a few weeks (even longer if the surgery is a shoulder/back/knee joint) to get the body and joints loosened up / gain some flexibility for good range of motion in spite of potential scar tissue, and strengthen some of the supporting and core muscles before you get back into compounds.
Then when everything is feeling good and loose, start light on for everything, beginning with one exercise per session and slowly introducing more as you go so that you can rule out any injury or pain causers / narrow them down.
  • Like 1
Appreciate all the input guys.
Birds, the surgery wasn't joint or muscle related, and therefore won't affect my lifting at all so that's not to worry. It was just sinus surgery (septoplasty, turbinate reduction, etc.) so I was unable to lift for a few weeks due to limiting any head tilting/blood pressure rises, and how easily a nosebleed can reoccur.
Prior to that was a long travelling stint through Japan, so all up that meant around 2-3 months off.
Mobility is a must, and there have been some great suggestions to accompany that. I've had two basic sessions so far with light loads in some of the bigger movements to suss them out and how I bounce back currently.
I may just make a build thread as to not clog up this thread with endless discussion.
Cheers :happy:
Seems my shoulder still needs some time, I added a little bit of weight to some things on Friday and then did a little work on the car Sat/Sun and it pulled up a little tender =\
Where do I sign up for carbon fibre/titanium super composite power joints/tendons/muscles?
  • Like 1
No good, how bad are we talking?
Not sure, I've had some ultrasounds but still waiting on the docs assessment.
I've had 3 operated on before and it felt the same when it let go, big tearing then I hit the deck.
Oh well, looks like some time off and then get back into it slowly, again...
Stupid guts.
Inguinal hernia? Have to insert some gauze or whatever it's called and get more sutures yeah? That sucks.
Yeah, I've been there 3 times before, it sucks but recovery is quick.
  • Like 1
So has been confirmed. I have a small tear in my groin. Thankfully its not bad and doesn't require surgery.
Doctor has recommended 6 months off oztag and no stress to my legs. Walking is fine and jogging if i am up for it.
Also believes that my flexibility is disgraceful and i need to focus on stretching or go and do yoga
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
