  • Replies 100
There's always the cafe: not quite as much fun, but has a really good section of veranda around the corner, with plenty of seating, so it will more than suffice!
If we're doing the bbq thing, do you guys want to put in, and I'll get some sausages, bread, onions etc?? Or would you prefer to do your own?
This is assuming the weather is going to be ok: bom says it looks good so far...
well done micah, we all should bring a eskie and if the weather is shittie just drink the beers and take the burgers home(forecast seems ok????), and if the weather is crap we could hole up at the numinbah correctional centre i'm sure they would make us welcome and find our cars interesting
ps think i might try and meet up at Advancetown' will ring you on the day.
Yeah... I thought the correctional facility entrance would be a great photo opportunity!
leetom: ignore the pm I just sent: must have written it while you were posting here (typical!).
Ok, here goes: I will edit as required, but those who have shown interest are:
ARGH-ESS '97 RSFOUR
IIJI S2 RSV
RUBBA '97 RSFOUR
BERNARDSHORTY '97 S1
PIXEL8R '99 RSFOUR
OLDIE '98 RSFOUR
LEETOM S1 RS FOUR
CHOOK '00 RS FOUR
66YOSTAGEA '96RS FOUR
STAGE1 '97 STAGEA
DARRINSPENCER S2 'TYPE-R'
WHOOBY S-TUNE
STAGECOACH CROTCH ROCKET
SLEEPYNIGHT 260RS
GREENGHOST RS2
ANTONY
RB26STAGEA '97 RS FOUR
So.....
I will update as needed, but as it stands, anything more than 50% attendance will make this the largest Qld gathering so far... The more the merrier, people: let's make this a big one!
Negative.... teh crotch rocket has been sold to pay for my compliancing. Will be a no show.
Any other veggie guys coming? If not, I'll flick the fake flesh and pack my own! I just need a packet of chips and a soft drink as I am hoping to listen, talk and learn lots!
I'll be bringing my old Apexi rear muffler of my R33 if anyone just want to spice up their exhaust sound without too much more noizzz! Worth a bit but I'm thinking about $120 would convince me to part with it! It's a big barrel with standard in and 5" out tip. Simple and solid-looking!
i i j j
HI
I will be on my one so I will probably grab something from the BP and take it with me.
I don’t know if any others are interested in the BBQ but I will still put in if this helps
As far as the weather is concerned I am going to take sunscreen and a hat. That’ll chase the rain away
Cheers
phil
1 more sleep :thumbsup:
I assume we're not all putting in for a sausage sizzle. Catch you guys at Coomera: this should be good: hopefully the weather stays fine (but cooler than today!).
I'll be there but the Stag will be DIRTY.
The time I allocated for cleaning was completely fu^^t up because of power outages. We are on rainwater and pumps, so no powa no wash
I'll just spray a bit of underarm and be sweet as a nut.LOL
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
