Hi everybody, ive had my midnite purple series II 98 R33 for about 5 months now, and have wanted to get it tinted for all that time but im finally financial enough to be serious about it.
What i was hoping to see from you guys is some photos of your tinted R33's and a quick description (name, darkness, price etc) of the tint you got.
I'm hesitant about going illegal with it, but if its necessary to achieve a decent look, i will.
Thanks in advance
Dan
Edited by chemical
https://www.sau.com.au/forums/topic/201396-show-us-ya-tints/
My mate has 20% tint... everytime cops rock pass he quickly winds down the windows hahaha
Dad's previous work van had some real low percent... 10% maybe? - had to wind down the windows to reverse through narrow driveways... that van eventually got defected though.
My previous car and current R33 has 35%... looks great and is practical for daily driving.
Edited by vietorious
my r34 is getting done 35% all round tomorrow from the group buy.
i just wanted to get legal tint as if i get defected i dont have to take it off.
Don;t you have the UV cut glass for the rear window, and little windows in the back? Cos i did in my old 34 and that was pretty damn dark.
