i got a external waste gate witha screamer but because of the yellow sticker i have put it into the exhauts but i kinda feels like the power is not the same is there any reason for this ??
was it tuned with the screamer ? maybe piping the screamer into the exhaust may have changed the a/f ratios at the oxygen sensor ? or it may just be the fact that screamer pipes offer a massive horsepower gain over going traditional that you can now feel the loss
https://www.sau.com.au/forums/topic/201729-sreamer-pipe/#findComment-3584412
Because they exhaust you have isnt good enough :/
Ie, not free flowing…
You need a proper, decent system if you want to plumb-back and not have issues
Tune isnt really the reason for it, its the added restriction
https://www.sau.com.au/forums/topic/201729-sreamer-pipe/#findComment-3584459
man doesn't matter how much you pay for somethin.. that doesn't make it good...
if it feels doughy then it's because it's been made restrictive a screamer pipe will produce the same power as a properly designed exhaust no drama's what so ever. I work for an exhaust company and talked to the engineers about this several times... It's all down to the design
https://www.sau.com.au/forums/topic/201729-sreamer-pipe/#findComment-3584903
the system is a little under $2200 so i think it is good enough i was thinkin it could just be the flow and the tuning cos it was tuned with the screamer
Well, sorry to say... but for $2200 it clearly isnt good enough, otherwise there would be no performance loss at all.
Nothing to do with it "tuned" with the screamer, its after the turbo... therefore tune changes wont affect it.
Its being caused by pressure build up, which is a poor flowing exhaust first and foremost.
https://www.sau.com.au/forums/topic/201729-sreamer-pipe/#findComment-3585131
its the plecebo *spelling* effect man...
if u think it ''feels'' less powerful it will feel like that.
HENCE- if u have a decent exhaust and have mounted the pipe WITH the exhaust flow u will be FINE.
u probably are used to the sound
SOUND DOESNT EQUAL POWAH
Edited by r33cruiser
https://www.sau.com.au/forums/topic/201729-sreamer-pipe/#findComment-3585859
If your exhaust is free flowing, you will not loose any power going from screamer back to exhaust pipe returned.
I'm sure it doesn't SOUND nearly as fast though :blink:
+1
When i had my first car laser tx3 4wd, i had a screamer pipe for 2 years from my wastegate, then i had it plumbed back into the exhaust & it did feel like it had less power slightly, but when on the dyno it made roughly exactly the same power as with the pipe plumbed back.
https://www.sau.com.au/forums/topic/201729-sreamer-pipe/#findComment-3586483
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
