hey everyone, i recently got a new job and i have to drive pass around 3-4 speed camera twice a day.
so this is making me a bit edgey so i just want someone to help me clarify:
1, how much km do u have to go over the actual speed limit until you get snap
2, how long will it take for them to send a fine letter IF i did get caught
-pete
https://www.sau.com.au/forums/topic/201850-questions-about-fixed-speed-cameras/
1. usually over 10% of the speed limit, ie over 88 in 80 zone
2. not really sure on this but i think someone mentioned 6-8 weeks or something..
I've heard of many cases where they've been set to less than 10%.
DO NOT speed past them.......
From big-ass trips... speedos are usually set to be lower than the speed you're doing.... If you use a nav. unit, it always displays that you're travelling slower than what the speed ostates (they might not take into consideration contours however)... But the speedo-checks on highway to melbourne registered same speed as GPS; which was at least 7km/h under what the speedo read. - so don't get paranoid, but don't exceed the limit. Driving instructors recommend 3km under speed limit to do driving tests :blink:
I thought fines always come within 2 weeks?
Keep in mind that if is IS 10%, it's still not going to be a good measure, due to inaccuracies in your speedo, the camera etc. Just do the speed limit through the camera.
thats when a pfc commander comes in handy :blink:
If you know where they are why would you speed past them?
:blink:
like a few people have said, speedos in cars generally read about 5km/h over what you are doing. so if the speedo says 100 youre doing 95. so if you go through a speed camera on, or even slightly above the limit, you should be right.
cops with radar/lidar ive heard need to give a 10% leeway. add into account that your speedo is high as well..
many times ive been in a 100 zone, with the speedo reading 110 to 115, and a cop has been there, and i havnt been done.
10% are you kidding me? lol. It's more like 2 or 3km/h. so 63 in a 60 zone will most likely see you booked, as will 103 in a 100 zone. I have no idea who came up with this 10% theory, but it's bullshit.
your theory is no better
it's definiately not 2-3km/h
Too lazy to edit but:
http://www.skylinesaustralia.com/forums/in...t&p=3560020
afraid to say.. not a good year for me :)
Just curious to know, do policemen have a Flash on their Radars?? or any other speed recording device (Laser)? etc
I was doing abt 111kmh in a 100 zone :D:( silly me,
I think i saw a flash from behind some trees and an un marked commodore parked some 2km down on the M4
can't be sure if it was me, as there were a few other cars around me doing the same speed...
but then again, i can't even be sure if it was a police flash or some blue light i saw through the trees in a factory or sumthing else :D ..........
dam , sooooo anxious. hope i dont get anything in the mail.
Most radar's do not have a flash, if the radar operator sees someone doing high speeds they would radio the chasing car (in this case I assume it would be the unmarked commonwh0re parked 2km down the road) telling them that x person is speeding and to chase em down.
However there are new radar setups where the radar is on the ground and the camera is behind it. They need to have a good lock on ~3secs then takes a photo immediately. Quite easy to notice this.
I think all police officers are being currently trained to operate radars, all HWP's know how to use radar's already.
As for your case, ADR's specifies 10% tolerence for speeds, so maybe you are being paranoid.
from
http://rvcs-prodweb.dot.gov.au/files/ADR%201803.pdf
5.3. The speed indicated shall not be less than the true speed of the vehicle. At the test
speeds specified in paragraph 5.2.5. above, there shall be the following relationship
between the speed displayed (V1 ) and the true speed (V2).
0 ≤ (V1 - V2) ≤ 0.1 V2 + 4 km/h
The equation means as follows:
95 Being Indicated speed 90 being true speed.
0 <= 95 -90 <= 90*0.1 +4
0 <= 5 <= 13
So there for Indicating 95 but going 90 is in the acceptable range. Were are as
110 Being Indicated speed 90 being true speed.
0 <= 110-90 <=90*0.1+4
0 <= 20 <= 13 Which means its not acceptable.
So the allowable difference depends on the speed the car is actually traveling.
Put easier, your indicator must NOT be showing a slower speed then the car is travelling, and it must not indicate more the 10%+4km of the true speed
So In a 60 zone, your indicated speed must be between 60-70 to be ADR approved.
In a 80 zone, 80-92
In a 100 zone, 100-114
In a 110 zone, 110-125
You are wrong as far as NSW goes ( as we speak, plans are in place for much less leway) but you are correct as far as VIC goes, 63 in a 60 zone ,84 in a 80 zone and they get you. This is speed cameras only, its up to the cop if its a none camera speed trap. What gets me in the case of VIC is the fact that the equipment they use to measure speed has a plus or minus 3% accuracy according to manufactures guidelines, if I was booked for doing 63 in a 60 zone I would defend it in court and I would win everytime!!
yeah true. I still don't believe it's anything like 10% though. Someone please drive through a 110 camera at 122 and tell me what happens :P my guess is fine.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
