Hey guys,
ive tried researching this & have searched various threads also. My R33 has quite hazy headlights which can be riden with various products such as Mother's Plastic Polish etc. Wat im wanting to do is remove the scratches on the lights, im wondering if anyone has used these novus products to do so?
http://cgi.ebay.com.au/NOVUS-Plastic-Polis...1QQcmdZViewItem
First two products seem theyd work a treat but i dont know about the third, mayb a lil too abrasive. I dun want to ruin my headlights cos a new pair wuld cost a bundle...thanx in advance! :D
https://www.sau.com.au/forums/topic/201909-cleaning-r33-headlights/
Personally, I just used some extra cut cream polish (for paint) and they came up pretty good. No need for these "plastic specific" polishes, all the same stuff i reckon, just re-packaged to jack up the price.
I agree. Mine were really bad when I got the car, my mechanic said to hit it with some 1200 wet/ dry, then cut and polish. They are as clear as glass now, looks so much better. I usually cut and polish them every few months as they start to go a bit cloudy again.
I've cut and polished mine - looks alot better than when the car first arrived... but it still has some yuckiness to it - it look as though its on the inside of the headlight... should I keep going with the cut and polish?
I'd say yes. I did mine about 10 times to start with, each time getting better and better until it was perfectly clear. When they are wet do they look good? Usually they do and that suggests that everything is on the outside. Might I add they didnt look too bad when I saw your car at Auto Perfection the other day, nice car. They didnt put a sticker on my car, did you get one?
Not sure on the wet thing but probably take a look at it again later - can definitely see the yuckness in the sun.
And yeah I got a small sticker just underneath the rear windscreen wiper.
Hey all.....is it just the 33's that suffer from this or do the 32's & 34's have the same problem.....mine seem pretty clear.
I suppose it's a combination of fall out and UV that causes the problem?
They all do. My old 34 suffered as well, and fixed it with some plastic polish (and lots of scrubbing).
use Autosol metal polish. they come out fkn crystal clear!
Yeah I use something similar on the bike's stainless steel just before a show and you can't tell if it's stainless or chrome.
'Liquid Reflection' metal polish.
Il be giving that a go soon but any idea how to take the clear cover of the light so i change the chrome to black?
u gotta heat the plastic up and pry the cover off with a screwdriver, its sealed on with urethane :)
Damn those headlights were filthy!
thats actually what the lights look like after sanding them :(
the pic quality wasnt too good cos i used my phone cam
all we do at work when we get 2nd hand headlights and they are like that is just get cut n polish and scrub away and they look like new! we just use the normal cut n polish you use on the car paint. works fine
Before trying any expensive polish, try getting a rag/cloth and rubbing toothpaste onto the headlights. Its not perfect but I've found it does give quite good results. Just make sure not to get any on the paint!! This goes for any cut and polish as well. Normal polish is ok on paint but cut and polish will normally wreck your metallic/pearl paint.
Pretty sure all skylines have this problem with faded headlights. Stageas are the same too. :)
  • 1 year later...
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
