Just wondering what oil pressure a R32 GTR will run at idle and revs when hot and cold. Also what eng oil temp do they usually run. I thinnk my oil pressure is a little low and the oil temp seems to be alot higher than it usually has been. oil temp is up around the 75 to 80 deg even on cool nights. It has a big oil cooler on it. The oil pressure is below 4 kg/cm3 at idle when cold and is back to near nothing when hot. I havn't checked it with a mechanical gauge yet but will be maybe this week end.
https://www.sau.com.au/forums/topic/202552-r32-gtr-oil-pressure/
I just started a brand new engine (with forged internals etc), and at idle when cold the oil pressure is about 6.5kg/cm3, and drops to just under 4 when hot. Ive only idled it around the local street because its untuned though. The oil temp doesnt go above 80 degrees when hot, with a large oil cooler. Both gauges are greddy expensive ones.
Shaun.
  • 2 months later...
dont listen to the ppl tellin u to change ur oil. its not ur oil. its the sender unit.
mine also did the same.. i shit myself real bad when i first noticed it.. it was @ 0 @ idle.. but after a few days i noticed that even when its on 0.. the light doesnt come on.. u know why??
because they run 2 seperate systems. 1 fails.. the other doesnt. put an aftermarket gauge on it and ull see the difference :cool:
  • 6 years later...
Hey All, I think I need some similar advice to this post.
I just bought a GTR in QLD that I have driven back to Melbourne over the last few days. I never really paid any attention to the oil pressure to begin with, but noticed today it was on zero - but the car seemed to be performing fine - great even! it did over heat on me yesterday somewhere in central NSW but it seemed fine again after a rest. I have noticed it seems to be running hot, & im not sure why.
When boarding the boat we were in the waiting line with a lot of idle, stop start etc with the engine getting rather warm. The oil pressure light then came on, with it barely idling, coughing & spluttering. I turned it off for a few minutes, then it was fine again & didn't miss a beat getting onto the boat.
I write this now sitting in the bar with a beer, freaking out! im hoping the oil pressure issue is related to the over heating, & that is hopefully something simple like the thermostat?
The motor has been rebuilt & I have all the receipts for it, I am living in hope its not the motor...
what should I be checking?
Im thinking if oil pressure light came on while it was spluttering might be that it almost stalled itself and as such dropped oil pressure enough to set off the light, but probably kicked itself back to life.
Have you checked the dipstick? Overheating could be a lot of things and it will need to be narrowed down.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
