Ignitiondvd Hot Spots + Dyno Comp!, Friday The 1st @ R.e Customs
  • Replies 123
...wow this looks like its gonna be huge!
Will hang back at work till 730 then head down.
:sad face due to measly ~300 run in tune:
trust me, that's more than alot of cars will be making.. including mine >_<
doesn't matter if your car isn't making massive power, just come down, watch or enter the dyno runs and get some free giveaways :banana:
shaping up to be a big night!
As per the other thread I'll be down there, to find out how much awkw my car is running. The mods are well...not completely known >_<.
Hopefully I'm making some decent power.
Anybody from around Bayswater going? wanna gimme a lift? >_<
..or pick me up from a station some where?
if anyone can help out gimme a buz on 0420974417 :banana:
my comp is being repaired atm so i have no net..
Edited by Jezza-gtR
I will try and make it.. Ill see how many other boys i can get down there aswell..
As for the ignition DVD.. it struggles as far as cars go, but the owners are HILARIOUS! :D
i've only got full 3" exhaust and one of those $30 boost controller jobbies, so i ain't going to be running huge numbers... i'll just be doing it for the curiosity factor of knowing what my car is making. Never had it dyno'd before
but yeah, between here and NS.com, sounds like it's going to be packed...
how many cars could they run back-to-back in say a 4 hour period?
dont know thinking about it
as i dont have alot of cash at the mommet as im heading to qld next week to do the whole theme park shit and yeah party for a week
so im trying to save money for that
but we see how i feel i just told friend in his aristo and he may enter but we see i think about it
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
