Hey guys;
I've been toying with the idea of a Stagea as a family car for a long while.
Recently, have noticed that M35s have suddenly become very reaonably priced -
2002 M35 Stagea $19750
2002 M35 Stagea with Leather and TV/DVD $22000
There are still many Series II Stags selling well in excess of these 2 low km examples.
Any thoughts as to why these M35s are so cheaply priced?
Edited by f3nr15
https://www.sau.com.au/forums/topic/203594-why-are-m35s-suddenly-so-cheap/
coz they are as ugly as a thalidomide baby?
just sayin.
Hey.......the eye of the beholder :)
If I can refer to a previous girlfriend, she performed really well and had great mods, was fun and looked good.
Then I was required to get a new girlfriend newer shape with average mods, but was far better to drive all the time.....and looked different to the other one.....
Once again eye of the beholder........ :banana:
I wish I had the answer to that question, very good value buying though I'd say.
Probably somewhere between: where they should be priced, real costs from purchase in Japan to being on the road here - and the fact that "literally" no one knows what they are still.
The price probably won't go back up though sadly...
They are now 6 years old and hard to get registered in Japan. Past experience shows that as soon as any car gets more than 5 years old the prices drop as more and more become available.
Cheers
Gary
Hey guys;
Yup....
1. Although advertised as an AR-X they are not
2. The silver one is a sports pack (Still good value)...looks to be an RS but without the gauges
3. The white one is a poverty pack with options. TV(Needs to be converted to PAL)/DVD Navigator(Doesn't work outside japan....also it does not mean that it play's DVD's as it is a DVD Navigator not player) (Still good value)....looks to be an RX
4. Headlights are illegal(not that thats a bad thing)
5. Dual Climate control....check it first!!!
6. Fuel prices(If you care about those thing's)
Edited by Jetwreck
just sayin.
Hey Dale, at last something we can agree on!! :(
Also... my opinion.....
These are very average cars in Japan.... and therefore because most people want something a little different, the prices are lower. There are lots of them at the Auctions.
It really comes down to supply & demand.
And they are FUGLY....
(apologies to all current owners.... haha)
Oh and most S2's have also fallen drastically....... :)
I spend more on tyres than I do on petrol. :(
Rego and insurance costs more than petrol. :)
Depreciation makes petrol look cheap. :)
Cheers
Gary
30,000k pa.
Tyres.....$1000
R&I........$1800
Dep.@10%...$1600
Petrol...30,000@15l/100 $1.40.... $6300
Mtce, oil changes etc .......$1000
Total... $11,700
WTF
Edited by 66yostagea
Hey.......the eye of the beholder :(
Once again eye of the beholder........ :)
New girlfriend is kinda fat, but still has the same size boobs.
30,000k pa.
Tyres.....$1000
R&I........$1800
Dep.@10%...$1600
Total... $11,700
WTF
10,000k pa.
Tyres.....$3,300 (the tax man helps me pay for race tyres for the R32GTST)
R&I........$2,400 (includes race car & enclosed trailer insurance as the Stagea tows it)
Dep.@15%...$2,500
Petrol...10,000@14l/100 @ $1.50.... $2,200
Mtce, oil changes and mods .......$2,500
Total... $12,900 >_<
Cheers
Gary
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
