Nope, we modified the original. At the time there wasn't enough interest in GTRs to warrant the need to make a mould of it.
Oh u killed it hey lol.... just out of interest what was the original kit worth to buy?
Arm + Leg + First Born :worship: , The kit itself is not that expensive (2K+) its the freight from overseas (3K+)
OUCH and that kills another dream lol. And its not easy finding a company that makes a copy... have searched around and so far have found.... zero!
I like the idea of a 1000hp GT-R looking as close to stock as poss'. Iron fist, velvet glove, and all that jazz. One would imagine someone who aims at a 1000hp GT-R has some sort of idea how it should turn out in the looks department.
Good luck, whatever kit you go with(cringes at thoughts of garish, tempe tyre pinup GT-Rs...). Personally, I want to see the dyno sheet of your car that actually says 1000hp...performance comes first! I hope you budgeted for BIG brakes...
Personally I like the stock GTR kit, especially series 3. Except the lower lip is way too overpriced.
I also like my kit as well >_<
Does anyone know what this kit is?
It looks a little like a 400R front bar without the N1 vents but the lower lip looks different.
Are the side-skirts 400R?
And its got rear pods too...
Brembo 6 pot fronts with 375mm discs and 4 pot rears with 340mm discs.
615kW @ 4 wheels @ 1.76 bar boost. (ported to the max)
  • 1 month later...
thats a real beuty cs student. after having rear bar kits on previous cars i am not a fan of them anymore.
but u just cant beat thos rear pods. they are agressive, and not too ricey.
cant beat that
* also go the top secret kit....freaking awesome
Edited by r33cruiser
What about the wisesports gt500 widebody kits for r33? a user on her by the name of GTN1K pretty much took out all the auto salons with the kit fitted to his white gtst, it was absolutely magnificent, i have seen aaaaaages a go a white r33 gtr for sale with the widebody kit on it.
the kit only looks good though with 19's.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
