Hi All.
I just thought i would let you all know about a club organised all welcome track day at mallala.
You dont have to hold a CAMS licence day licences are available through the Mitsubishi GSR EVO Club on the day
i have attached the entry form to the post
This event always has a good turnout so be early to register.
Cheers
Chris
Link to MGEC forum
http://gsr-evo-club.net/forum/viewforum.php?f=76
ENTRY_FORM_for_TRACK_DAY_EVENT_2008.doc
Edited by mad34
  • Replies 48
i wanted to go to come and try day @ Winton just recently was my kind of price $30 no cams needed
http://www.skylinesaustralia.com/forums/Wi...ry-t202616.html
our track is shit, but in saying that would still have a go when i get brakes
so who's going to get embarrassed by a mirage? :banana:
chops & blue32 know what i'm talking about
Quite a few I'd reckon - those mirages are getting quicker these days hehehe. Even hairdressers have to get to work on time........(Matt should love that comment!!!)
I am currently dropping in a forged rebuild in the R - after not driving the beast for 4 months did a comp test and found no 3 @ 120psi with the other 5 @ 145psi +-5. Lower compression explained by thick metal gasket, but no 3 is doing its own thing........Long story short - if its done, I'll be there. Reckon I can improve on the 1:22 with my new to add 80kws, semis and cooling system that actually will work!!!
will be a good day.
Its worth coming, on a day like this there is nothing to prove just come out and have fun.
We are all hoping to get a solid 5 sessions in, which is more than enough.
This is a well organised event plus its only cars so no karts etc.
The club is looking to have a time attack later in the year so this will be a good chance to get some practice in for those of you that have not tracked your car before.
And yeh Matt's mirage is pretty quick! for those of you that have no idea what we are all on about grab feb's issue of fast fours.
Hot!!! ....have been waiting for another one of these.... I am super keen and will be there with bells on!!
Ps. Anyone know what the closing date for entry is? Can't see it on the entry form.....
Edited by HOSTILE
Closing date will be when there is no more places.
Last year people were turned away as we had a full event.
first post updated with link to the MGEC forum track day section for any other questions that you may have.
i should have my new diff, brakes and clutch in buy then. and possible the oil cooler
im deffinatly in.
Sweet!
be sure to get all forms in early.
Will be an even better day if plenty of skylines roll up!
My brother will be there in his 33
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
