  • Replies 569
Posted Images
dunc i have done f#@kall on the r34 , mark is a machine when he put his mind to it.
about the most i did was pull all the vinyl crap off the carbon boot , took about 6 hours! still got the bonnet to do:(
for some reason the japs had decided to vinyl sticker the body panels on the Tomei drag car instead of painting them.
Believe it or not, Vinyl is quite a bit lighter than a normal paint job. The RS spyder that races in the US in ALMS is made yellow only by vinyl. Saved about 7kg from memory. They look so much better in raw carbon but sponsor dollars talk!
hey russ, great build you got going here ... im sure it will be a stand out at the track just like your other cars....
i was wondering if youd post up some more pics of your black street r32 gtr please???
im building a low km original black v spec 1 and im running out of motivation as its dragging out a heap longer than i had hoped , seeing a mint one would surely stir me along!!!
keep us updated on the 34 too!!! , cheers
Sorry ignore my last post, you said street R32, my bad. I thought it was blue though, not black?
Yep thats the car, it's got a very faint purple in it, looks black mostly. The thing is mint, we did some practice recce in it and it drives like a new one, and yes, I'm old enough to remember driving a new one :)
Looking great Russ. Come a long way since those seem welding pics ya sent me.
The engine 3ltr with a twin setup , and 6 speed sequential holinger box with load sensitive gearshift rpm cut.
Why did you and Mark decide to go back to twins? Thought the To4z kit was going on this one.
Cheers Coop
Okay guys
finally an update!!
thought you might like to see how the r34 is coming along, still lots to do.
but we have done trial body fitting, engine and gearbox are in along with front and rear crossmembers and arms, most of the electric are done.
still needs suspension and engine management , all oil and fuel system etc etc etc
front wheel track will come out another 30 mm yet!
lots and lots of hours gone into this car already and so much more to do.
hope you like.
:laugh: That is honestly the best 34 I have ever seen! Bloody unreal!!
Top work mate
Looking forward to the vids! :thumbsup:
Hey guys
thanks for the comments! i cant wait to see it on track.
we decided on twins after driving the r33 with a single and we just preferred the twin set up, ( with more work the single my have gotten close but we decided against spending all the time required trying)
and yeah that is air jacks on the sills.
hopefully the autronic ecu and assciated items go in next week ready for fire up!
another pic or two
cheers russ
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
