What makes you say the blocks fail/flog out?
Most of the problems on the Sierras were turbo related and headgasket related. Followed by electrics/tune/ecu glitches. LOL, which usually meant the headgaskets went bang and they typically overheated. I don't know of too many instances where the blocks failed. Maybe in the RS days pre 200 series blocks but not in the RS500 and Group A rallying and circuit era
  • 4 weeks later...
  • 6 months later...
  • 1 month later...
That's GTR money for something with a pinto motor ;)
It's sure a long way from home, must be
Looking for that special collector at that price. Fair few sierras have been changing hands over here.
For anyone in Sydney, head to sydney retro speedfest on this coming weekend. Two Gibson GTRs will be going for it in the heritage touring cars. Plus the normal mix of skylines, sierras, commos, BMW, jag, and others.
are you talking about my stuff up with the RPM?
"80hp and 4,500rpm and full power at 3,900rpm" :stupid:
lolz
Did it have a boost curve anything like this? (stolen from the Hypergear thread, he had issues with the ECU commanding the boost solenoid).
  • 1 month later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
