  • Replies 69
http://www.skylinesaustralia.com/forums/up...59916_thumb.jpg
Just a question... why go to the trouble of putting nice gauges all the way over on the other side of the dash when the only time you would read them is when you were drifting around a right hand bend, at which point i would be watching the road rather than my gauges? I can't even read the numbers without blowing up the image.
I'm by no means having a dig at you for it, as I believe everyone should modify their car in what ever way makes them feel good... I just have never understood it???
I will say that I am happier to see that you didn't just get the hole saw and cut straight into the dash like some... very handy work there with the glass mate, well done.
but the thing is if you know what the gauges are (ie position) and what the needles usually sit at, all you need to do is take a quick glance, check the needle position and see how its going....
it the same with the gauges place under the head deck near the shifter - its hard to read them there aswell....
Foremost expert speaking!
well here is my piller pods i have been doing
i know i could of bought them but thought i will just make a custom one
whats yous think
also car is heading off to briffa this thurday for piping
Edited by Flash89
hey guys
car was dropped off the briffa on thursday for the IC piping and was all finished today, mick wasnt kidding when he said he will have it done by the weekend , but couldnt get a tow so car will be back to beyond for wiring tomorro yay
i guess i will find out in the next 2 weeks, cant drive hard straight away got to wear in the clutch. also i think i will have a problem with traction cause it getting into the rainy weather :) hehe
i never understood why 32's have a break duct on one side but not the other lol. oh well
It's for the stock intercooler..
Anyway, nice work Flash - always good to see another rwd 32 getting a huge power upgrade :(
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
