  • Replies 69
its not there yet :ermm:
Yeh i got excited...
Also i reckon between Top Gear and Fifth Gear i reckon Fifth Gear is the more objective, enthusiast-targeting of the two shows.
But i prefer TG, and it's still a solid motoring show...just sometimes all the excitment blurrs the seriousness of the content.
Perhaps because FG is much more dull i take it to be more 'realistic'.
Meh.
That's because it's only just after midday there.
Don't get your hopes up for a 15 minute review with track times etc. Apparently it's only a short review and jason plato was impressed, he loved the DSG but was a bit nit picky, mentions a bit of understeer.
Going to have to wait for a while longer until Nissan provides 5th gear and Top Gear with a GT-R to really flog (the one driven by plato is a customers imported GT-R which is the first one in the UK)
I liked the review. Looking forward to Clarkson's take on it ("that gearbox is an absolute shi**er") but for what it's worth that review wasn't pretentious. Could've given a little more background and made the review a minute longer.
Thanks for the links.
They could of put it up against something else at the track, or timed it at showed it against other cars times in its range, or even raced it against that R33 GTR they had at the start - what was the freaking point of showing that R33 GTR at the start?!?
The R33 GTR was a giveaway in that weeks show. You know how they give away a car every week.
Anyways a better quality version is on my blog now, Youtube was pretty lousy for quality:
http://www.gtrblog.com/index.php?blog=4&am...p;tb=1&pb=1
the f*cking play station generation again. That was THE MOST unimaginative, unoriginal, boring review ever.
JC basically reviewd the R34 GTR in exactly the same was with it's MFD, and tried to get laughs that way, which was kinda funny the first time. Then the prev TG presenter, the fat guy, used the EXACT same playstation, g-metre type commentary and then proceeded to say that GTR's constantly crack brake discs??? :D
Now this knob jockey comes along, obviously having seen previous reviews of the R34 GTR and spills out that exact same crap! "Playstation generation" "let's see how many g's i can pull.." *acts surprised at the readout and sarcastically makes note of how impressive that is to other people* - That review was nothing but plagiarism.
I have yet to see ANYONE else write anything about understeer, and if anyone was going to notice it, it was the Autocar guy. He really did give it a flogging, and knew what he was talking about.
But not much of a surprise really, the presenter does own a 997 Turbo :P Face it mate, your however many thousand pound 997 Turbo is a slow car compared to the R35 GTR!
JC basically reviewd the R34 GTR in exactly the same was with it's MFD, and tried to get laughs that way, which was kinda funny the first time. Then the prev TG presenter, the fat guy, used the EXACT same playstation, g-metre type commentary and then proceeded to say that GTR's constantly crack brake discs??? :P
Now that you mention it... it does seem like a facsimile of the Clarkson 34 review...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
