Spotted Nightcrawler this arvo on North East Rd, tooted ya and waved buddy but was in the work ute, you probably didn't see me
sorry Luke didn't see or hear you mate - I often drive along in my own little world :D
this is why air horns are good :)
sorry Luke didn't see or hear you mate - I often drive along in my own little world :)
spotted a S1 R33 4door black by the looks of it and also @ same time a white R33 on south road just after 3:30
Luke go install sof2 :D :D
Spotted a red R33 on cross road at goodwood road, was heading east, had sau stickers on rear quarter windows... I was in the blue 32 GTR stopped at the lights.
Also silver R32 in APS on south road, looked good from the back.
haha yeh i rekon every1 in the effen petrol station would've. yeh i will! everytime i see some1 in a skyline i wanna go and say hi but i think "if they arent from the forums, i might get a grunt"
Nah, see the dude in the 32GTR there? I didn't know him, just went up and started talking, if they don't want to talk, you'll soon get the idea but most Skyline owners are top people :ninja:
yeah +1 to 99% of skyline drivers being approachable
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
