Spotted Andrew on Pirie Street ....
haha was I making a lot of noise? I was doing a bit or over-revving as I love the boom of the RB off the tall buildings in Pirie St :P
spotted a bright yellow r34 2 door in BP on corner of Henley beach & south road around 1pm yesterday
spotted a maroon r32 with a white front bumper around 2pm today - -
spotted a white r33 cranking down henely beach road around 2pm today too.
anyone??
spotted "VSPEc 33" on port rd..............looks very nice
just saw some dick head that lives up the road drive past my house a millio times in his silver 33 with no front bar.......yeah ur cool mate...not
and saw a white r34 4 door with nismo front bar on bridge rd with a girl driving it
That is my brother-in-law David .... Red Back on here .... it sure is one nice '97 R33GTR VSpec 2 with an R34GTR MFD and all the cool toys
was driving around today looking at house;s for sale for a investment property local to my area and spotted a white stag parked on the front lawn of a house :-) i know who;s it is lol eh cupcake
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
