Spotted a purple R33 with PINKBTZ or similar on the plate - that thing needs some wheels, stat.
Mad props to semi trailer driver with a load of bricks on board, who nearly ran me off the road trying to tell me how good my car was...
sure it wasnt a 33 4 door??? and do you mean west lakes?? If so then yeah it was Ryan and myself
Sorry mate it was from a distance....Yeah West Lakes.
Some elizabethian scum idiot tailgated me on the port river expressway this morning because he doesnt like Skylines being infront of him.... so yeah I kept well below the speed limit for the length of the way and didnt let him pass until he turned off - and boy did he zoomed off, not a happy chappy - serves him right.
dose dose dose dose dose.
need to block off my bov so it doses bro...
anyways, spotted a black 34 puttering through a school zone on uleh road this mornin (8:30), looked sweet, sat a bee's dick off the pavement, fat set of gold bbs wheels, had a decent note to it aswell.
Spotted Ryan in the Stag again this morning :D bolivar rd this time
lol.. i hope he was behaving. What car are you usually in when you see him? Or are you at the bus stop? If you wave he said he'll wave back at ya!
I was on the bus this morning waiting for it to leave. He wouldnt see me through the obviously defectable tinted windows of Adelaides Buses.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
