Spotted a few Skylines in Elizabeth this afternoon, 4dr pearl white R33, white r33 2 door, silver r33 s2.
Also about 9-ish spotted MYCEF3 on Portrush Road. Your rims look good ;)
Hey man cheers
Yeah was heading down 10 mins past salisbury for a friends house warming!
BTW where were u hiding???? i was in my own little world driving or talking to the missis!
Hey man cheers
I was a passenger in a VZ SV6 haha
Spotted black 32 about 4:30 on hub drive while walking my dog.
Also spotted young fella in old supra kick it sideways after staring at my 33 on way to shops on hub drive around 6pm
ABE twice yesterday, once at work.. then cutting thru maccas car park about 4-430ish
... :D ...hmmm, yup sounds about right, went and got petrol after work so my car had a full tank for this week. Booked it in at Horse Power In A Box today :) , 250rwkw + for me in a few days.
On my way to Horse Power In A Box, spotted a greenish/bronze Stagea going along the Lonsdale Highway.
Spotted a White 34 with the Night Kids sticker on the rear quater window this morning in Aldinga.
Yeah spotted that as well! I dont get it... The night kids (initial d series) NEVER had a 34!
One of the gods had a 34 but "GTR" (god hand or god foot... not sure)
putting a night kids sticker on a 34... Its like putting a red suns sticker on a RX-8 :(
Seen a black 32 with the night kids sticker.... THAT is better :D
2 cents :D
Edited by MYCEF3
Bit late but spotted a 180 white black top on doctors rd saturday or sun
Silver s15 and a black aristo yesterday morning on goodwood rd
And some commo being a DK king (suprise suprise) :D
putting a night kids sticker on a 34... Its like putting a red suns sticker on a RX-8 :D
btw you do know the owners of those cars are on these forums :P
and while the 32 in the cartoon was black the 1 u seen aint just looks black at night :(
Edited by Inline 6
Spotted an R33 parked on military road with blue flames up the side, body kit, and if everything else wasn't bad enough some 20" +60 rims aha,
Looked really really bad, I find myself asking.. Why would you? Haha. Kinda like seeing fat chicks wear belly tops, Why would you? Who told you that you look good enough to leave the house ahaha.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
